Daylight Light went out, then back on...
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Daylight Light went out, then back on... in Cadillac Escalade Forums; This weekend I saw my 2002 Escalade through a reflection of another car in front of me and noticed that ...
    invincible569 is offline Cadillac Owners Member
    Feb 2004
    87
    This weekend I saw my 2002 Escalade through a reflection of another car in front of me and noticed that one of the DLR lights was out. I didnt think anything of it and was going to replace it. I stopped at a relatives place and it was still out. Came home 3hrs later and it came back on. Is it loose? Or is a computer problem? Today its been on all day. Thanks!
    z1st is offline Cadillac Owners Member
    14
    Re: Daylight Light went out, then back on...
    i'd guess a loose connection or bad wire if its only one side. maybe got wet then dried out? i like to use the dielectric silicone grease on all my electrical connections and when installing bulbs-seems to eliminate moisture and corrosion issues.
    PistolPreeth's Avatar
    PistolPreeth is offline Cadillac Owners Fanatic
    157
    happened to me as well. i am running upgraded PIAAs. Haven't had an issue since
    outofdablue is offline Cadillac Owners Fanatic
    May 2004
    Philadelphia
    411
    Sounds like a loose wire somewhere. If not the wire try changing both bulbs as a set.
    Feb 2004
    87
    Ok guys I have an answer to my problem. I just replaced them both and the one that was having the problem (bulb) was corroded. The bulb has two contact points and one of them was burned out.
    Just a note.. it was VERY easy getting to the bulbs, but what a pain in the butt it was to take out the bulbs!!! I had to have my wife help me hold back the clips so the bulb would pop out. I guess you could say those bulbs will never fall out!
  8. Remove Advertisements
