Originally Posted by luxurylife33 |
Good info on this site:
Directions For Use
Return to SEM Classic Coat for Leather
Directions for use
Preparation:
Vinyl:
# Clean first with SEM SOAP and a gray scuff pad, paying close attention to textured or recessed areas.
# Rinse with water. If contamination still exists, water will bead on the surface. Repeat this step until beading no longer occurs.
# Next, clean thoroughly with VINYL PREP using a clean lint free towel and wiping in one direction.
# Rinse with water and dry.
Leather:
# Wipe with a clean damp towel to remove all residue and allow to dry.
# Next, clean with SEM PLASTIC/LEATHER PREP.
# Scuff the leather with a clean, gray scuff pad and clean again with SEM PLASTIC/LEATHER PREP.
MIXING: Agitate thoroughly! Shake can vigorously for one minute after mixing ball rattles to ensure color uniformity and to prevent clogging. For best results, use only when can temperature is approximately 70°F (21°C).
APPLICATION: Apply light “mist” coats, allowing 5-10 minutes between coats.
It should be noted that even though film is dry to touch, the substrate should not be subjected to heavy abuse or abrasion for 24 hours.
NOTE: Spray tip may be adjusted for either a vertical or horizontal fan spray pattern.
