How To: NavTv - Nav Tool - Video interface for the stock Delphi Navigation Screen - Page 7
Page 7 of 9 FirstFirst 123456789 LastLast
Results 91 to 105 of 129
Like Tree3Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, How To: NavTv - Nav Tool - Video interface for the stock Delphi Navigation Screen in Cadillac Escalade Forums; The only issue I foresee is that there won't be enough room back behind the head unit. I have had ...
  1. #91
    T-Giv's Avatar
    T-Giv is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade ESV
    Jun 2008
    Colorado Springs, CO
    28
    216
    Re: How To: NavTv - Nav Tool - Video interface for the stock Delphi Navigation Screen
    The only issue I foresee is that there won't be enough room back behind the head unit. I have had trouble getting just my ipod box and such back there so with all this other business I don't know if I can get it all in there.
  2. #92
    dssrocks is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade Ext.
    Mar 2009
    43
    74
    Quote Originally Posted by sfv41901 View Post
    I just did a search on ebay & this is a pic of what they have. This looks nothing like the on you bought.
    Seller: metroholdingslimited
    I just purchased this one, will post my results.
  3. #93
    sfv41901's Avatar
    sfv41901 is offline Cadillac Owners Connoisseur
    Automobile(s): 08 CTS
    Jan 2009
    Palmdale, Ca
    38
    1,249
    Quote Originally Posted by dssrocks View Post
    Lets us know if all those wires come with it.
  5. #94
    Mar 2009
    43
    74
    Nope, looks exactly like the one in these pics at the begining of this thread other than the box is black, it is a PAC VCI-GM2.
    Although I am confused of an optional part that is shown called an SPDT relay. Not sure what this is for and why it would be optional. Anyone?
  6. #95
    luxurylife33's Avatar
    luxurylife33 is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Escalade (sold) 03 Escalade EXT (sold) - 07 Escalade EXT
    Oct 2008
    Long Island
    29
    1,363
    told you none of those wires were necessary....
  7. #96
    Mar 2009
    43
    74
    luxurylife33,
    I have completed my install and everything works great, however I see some slight diagonal lines on the screen which would appear like interference of some sort. I know I am being a bit fussy as the quality is still great, but if this not normal than maybe I can try a new power source and ground to try and fix it.
    Also to check out whats behind me without putting the truck in reverse, I added an extra toggle button (normally open switch) to switch the backup camera on anytime.
  8. #97
    Oct 2008
    Long Island
    29
    1,363
    I would start off with the power source as you said. Try a thicker gauge wire for the + and - lines. If that doesnt work, your ribbon cable is probably not connected 100%. I had the same problem and had to wiggle the ribbon cable further into the slot. Hope everything works out for ya! I'm spending my day fixing my "service ride control" message today. I think i need a new compressor
  9. #98
    Mar 2009
    43
    74
    I am thinking the best power and ground would be from the factory deck. Do you know what wires in the factory harness are power and ground? Power is easy enough to find, but finding the ground wire may be difficult.
    Good luck on your compressor replacement.
  10. #99
    Oct 2008
    Long Island
    29
    1,363
    I just took a positive off the fuse block and a negative off the metal dash....
    BTW the compressor is good, its just not turning on .... relay is good too so im thinking its a sensor or something, bringing it to my brothers shop this week to get it scanned.
  11. #100
    Mar 2009
    43
    74
    Quote Originally Posted by Esco04 View Post
    New member here, just hooked up the Navtool to my 2004 Escalade EXT & installed a rear view camera too. You want to hook the power wire (silver striped) of the Navtool to wire B3 of the big main radio connector to get Retained Accessory Power.
    On my truck, looking into the connector, it's a brown wire on the top row 3rd from the right.
    I ran a separate wire for the camera + , used the Brown wire at the ignition harness for Accessory power. I attached a new Ground wire to the dash bracket bolt and used it for the Navtool ground and the camera ground wires. Works like a charm!
    Be sure you use B3 & only hook the Navtool + wire to it, like it says in the instructions. I mistakenly hooked it up to the B4 wire, which is next to the B3 & is also Brown, & when I opened the door it immediately drained my battery!
    Hope this helps.
    I tested the brown wire (3rd from the right on the big plug on the back of the head unit) like said above, and it would appear to be accessory power. Now I think I have accidently shorted this wire out or something as I now have no dash lights and there is no longer power to that brown wire. I have checked every fuse under the hood and by the drivers door and all are fine. Does anyone know ehere the fuse is or how I can fix this problem?
    Thanks
  12. #101
    carshop is offline Cadillac Owners Member
    Automobile(s): escalade
    Jan 2009
    19
    NavTool is 350.00 on that site.
    Cant find it on Ebay?
    Any help?
    Thanks
  13. #102
    Mar 2009
    43
    74
    Do a search for "nav tv escalade" and you will see one from metroholdingslimited.
    I purchased one from this seller a couple of weeks ago, works great. Made an offer and won the item for $180.00 shipping included.
  14. #103
    Oct 2008
    Long Island
    29
    1,363
    the guy i bought mine from is no longer selling them... try what dssrocks said^
  15. #104
    Jan 2009
    19
    thanks guys
  16. #105
    nathanjax's Avatar
    nathanjax is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 esKONali
    May 2004
    Jax, FL
    36
    1,099
    I'm looking in to doing this and I have a question that "it appears" hasn't been asked...
    Isn't this Nav-to-go piece basically the same as the PAC VCI-GM2 piece? Looking at the box, wiring, etc. it looks to be the same.
    http://www.pac-audio.com/productDeta...&CategoryID=34
    Thanks,
    Nathan
  17. Remove Advertisements
