MCGAUGHYS or GROUND FORCE?
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, MCGAUGHYS or GROUND FORCE? in Cadillac Escalade Forums; What is the difference between the two? price,ride, Looks Plus any know a good shop in the ATL,ga to install ...
    skillernk is offline Cadillac Owners Member
    9
    Plus any know a good shop in the ATL,ga to install the kit
    Infamous LadeOn24s is offline Cadillac Owners Member
    Feb 2004
    82
    Re: MCGAUGHYS or GROUND FORCE?
    Ground Force uses torsion keys which makes the ride stiffer therefor causing a rough ride. The Mcgauhys kit is a drop spindle which just takes the stock hub and everything and moves it up 2 inches. This results in a stock like ride. I have owned both a ground force and a mcgaughys and I will never ever recomend a ground force to anyone. I am sure in places that have roads like glass the Ground Force is great but I live in pothole central.
    9
    Thanks for the info now I just need to find someone to install the kit in GA
    02BlkEXT is offline Cadillac Owners Member
    May 2004
    65
    roughly how much is the mcgaughys kit, and how easy is it to install?
    gabbman's Avatar
    gabbman is offline Cadillac Owners Fanatic
    Mar 2004
    new jersey
    101
    its like $425 with the shock extenders installation is around $300 shop around
    jamesmbond is offline Cadillac Owners Member
    49
    QuestionRe: MCGAUGHYS or GROUND FORCE?
    I have a 2002 Escalade with the Ground Force and YES, the ride quality is crap.
    I don't have any of the original/stock springs or parts so does anyone know if I need anything additional to change to the Mcgaughy suspension. Basically, if I purchase the Mcgaughy system, are there any "stock" pieces I need to "go back to"?
    Thanks,
    JB
    Feb 2004
    82
    you could keep the rear the same and just buy the drop spindles from Mcgaughys for 200 bucks and you will ride a lot better. The crappy ride comes from the torsion keys.
  10. Remove Advertisements
