Rear parking sensors not working
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 53
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Rear parking sensors not working in Cadillac Escalade Forums; When I go into reverse all I get is one blinking red light and no audio??? Any idae on the ...
    coralreef35mm is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Aug 2008
    123
    Any idae on the fix?
    TSS's Avatar
    TSS
    TSS is offline Cadillac Owners Connoisseur
    Automobile(s): 07 Lade & 06 SRX (Gone); 2010 Enclave CXL; 2010 MKS Ecoboost
    Jun 2006
    3,673
    Re: Rear parking sensors not working
    I know sometimes snow on the sensors can screw mine up. Can't tell if snow is an issue where you live based on your supplied info. Also, make sure you did not accidentally hit the parking assist off button. My 07 has one of those buttons, and I am thinking yours might too.
    KrazyKeith's Avatar
    KrazyKeith is offline Cadillac Owners Fanatic
    Automobile(s): 03 Escalade
    Dec 2008
    Albany, NY
    336
    Quote Originally Posted by coralreef35mm View Post
    Hey coral-reef.
    Did you figure this out and get your audio back for the parking sensors?
    whosurpopi is offline Cadillac Owners Fanatic
    Nov 2008
    119
    I had the same problem, turned out one of the sensors came unplugged. The little clip that had held it in broke. I had to use tape to hold it on tight, and now it works fine.
    KrazyKeith's Avatar
    Dec 2008
    Albany, NY
    336
    Quote Originally Posted by whosurpopi View Post
    if a sensor is bad will it also mute the sound? if so, how does one know which is bad?
    will confirm nothing is unplugged 1st.
    Nov 2008
    119
    Yes, the sound was muted when it was unplugged. It could also be a bad wire (although I have heard of the sensors getting damaged.)
    luxurylife33's Avatar
    luxurylife33 is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Escalade (sold) 03 Escalade EXT (sold) - 07 Escalade EXT
    Oct 2008
    Long Island
    29
    1,363
    I have a red blinking light as well.... it stopped working about a month ago... no volume or yellow lights anymore
    bskaug420 is offline Cadillac Owners Member
    Automobile(s): 05 escalade EXT
    Jan 2009
    35
    3
    I just purchased my used 05 ext. I have noticed that i have the same problem. My single red light continues to blink but no yellow light nor any sound!!! i backed into my fence the first time i tried because i wanted to see how accurate they were!!! damn things don't work at all.. Im planning on taking my truck to get it fixed soon if nobody on here has any other advice for this problem. thanks.
    KrazyKeith's Avatar
    Dec 2008
    Albany, NY
    336
    If anyone knows how to diagonse the sensors to find the failed ones, and could share with us, that'd be much appreicated.
    I dont wanna replace them all if I dont have to.
    Some beeping assistance when I back up would be GREAT.
    Jan 2009
    35
    3
    Well i finally got to the bottom of this problem. I got bored this evening and decided to go outside and see if i could tackle this sensor issue.. I crawled under the back bumper and inspected all the sensor connections. I noticed that one sensor wasn't even plugged in. So i plugged it in and drove the vehicle in reverse. I ended up with the SAME issue. Just one red blinking light with no noise.
    So then i crawled back under there and noticed that the connection on that plug wasn't the greatest so i pushed it on as tight as i could and tightened it down as best i could with a zip tie. I then hopped back in and drove in reverse and all of the sudden there was a yellow light as well as noise. It is now working perfectly!!! This would be much easier to trouble shoot with two people so the one under the car could squeeze the plugs tighter as the other person keeps there foot on the brake to see if the yellow light comes on!! good luck.
    Nov 2008
    119
    Congratulations, That is exactly what was wrong with mine. I used tape to create the good connection, but the zip tie seems like a great Idea. By the way, I have four sensors that are new if anybody wants them. I purchased them before I found my bad connection. $200 for the set shipped.
    credmond is offline Cadillac Owners Member
    Automobile(s): Escalade Esv
    Jan 2009
    1
    Thanks. Mine has not worked since I bought it, I went under and they all looked good but i pushed them all tight anyways and now they work. I guess I should have tried that sooner.
    KrazyKeith's Avatar
    Dec 2008
    Albany, NY
    336
    I've got one that's unplugged, I tried to plug it in but it doesnt stay clicked in.
    Havent had the chance to do the "2 person" method, but I will try soon as I can, the weather here in NY has been COLD so its not even an option at this point to try. Hopefully I can get it plugged in or at least zip tie it as mentioned and have it work
    If not at least I have a feeling I know which sensor is bad (the unplugged one)
  16. #14
    Texasreb is offline Cadillac Owners Member
    Automobile(s): 01 DHS and 07 DTS IV
    May 2008
    8
    Quote Originally Posted by KrazyKeith View Post
    There is a diagnostic link in a similar thread using tag URPA, Ultrasonic Rear Parking Assist.
    If you can't find it, reply to my post here and I will get the email.
    I can't figure out to get to my sensor in my '01 deville.
  17. #15
    KrazyKeith's Avatar
    Dec 2008
    Albany, NY
    336
    Quote Originally Posted by Texasreb View Post
    Let us know
  18. Remove Advertisements
