Rear parking sensors not working - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 53
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Rear parking sensors not working in Cadillac Escalade Forums; hey guys, check out the end of the this thread http://www.cadillacforums.com/forums...ml#post1908057...
  1. #31
    zerocarpileup is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Escalade
    Sep 2008
    Chicago
    32
    207
    Re: Rear parking sensors not working
  2. #32
    COWTOWN SURVEYOR's Avatar
    COWTOWN SURVEYOR is offline Cadillac Owners Member
    Automobile(s): 2007 ESCALADE EXT
    Feb 2012
    60
    3
    My parking assist worked great for years with my reciever hitch attached. One day it stopped working . After a trip to the dealer and some embarrassment I discovered that the little black
    plastic /rubber trailer ball cover that I bought this weekend to cover up my rusty ball was just enough to set it into non working mode. Trailer hitch is still attached minus the cover and everything
    is back to normal.
  3. #33
    ddbrand is offline Cadillac Owners Member
    Automobile(s): 2006 Escalade EXT
    Apr 2013
    1
    I know this is an old post, but if by any chance you still have those sensors, I'll take 'um!
    Quote Originally Posted by whosurpopi View Post
    Congratulations, That is exactly what was wrong with mine. I used tape to create the good connection, but the zip tie seems like a great Idea. By the way, I have four sensors that are new if anybody wants them. I purchased them before I found my bad connection. $200 for the set shipped.
    I know this is an old post, but if you by any chance should still have these, I'll be happy to buy them from you.
  5. #34
    bigirb2002 is offline Cadillac Owners Fanatic
    Automobile(s): 05 escalade
    Mar 2013
    31
    119
    mine started working AGAIN AFTER i changed my oil lmao
  6. #35
    squiroz000 is offline Cadillac Owners Member
    Automobile(s): 2002 SLS
    Mar 2013
    Thank you so much. I did exactly as you said and I fixed it, the wires were loose. Again I appreciate the information.
  7. #36
    pro_usa1776 is offline Cadillac Owners Member
    Automobile(s): 2005 SRX
    Jan 2011
    53
    7
    Mine quit working too. Ill check the connections out tonight. I get a 4 beep alarm, and flashing red LED, when I put the car into reverse. I also have my rear brake lights that stay on when the headlight switch is on. If the switch is in the off position the brake lights work correctly.
  8. #37
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by pro_usa1776
    I would bet you have a bad ground as that will cause the issue your having with the lights
    The flashing red light means the park sensors have a trouble code in the system I can help with that
  9. #38
    John P is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Escalade 6.0
    Feb 2009
    Glasgow, Scotland
    159
    How do you find trouble codes CM?
  10. #39
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by John P
    The module is under the second row passenger seat(short wheelbase Escalade only) the test mode harness is next to it
    Jumper that and then put the truck in reverse(engine NOT running) and watch the display
    It will flash like this
    Outside red and outside amber
    Codes
    The test mode loops so it will give you more then one chance to get the codes
    To clear the codes afterwards just remove the jumper and drive the truck up to at least 25mph
    Get the codes and I will help out
  11. #40
    CaddyEscalade is offline Cadillac Owners Fanatic
    Automobile(s): Escalade
    May 2010
    231
    I am also trying to diagnose this on a 2003 Escalade, there are 2 things under the rear passenger seat. One has a black bosch module with a blue plug and the other is just a multi-wire plug connector. I'm not sure what I am to jumper? And where am in reading the codes from once jumped? Thanks
  12. #41
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by CaddyEscalade
    The Bosch module should have a small two pin harness likely taped to the larger harness
    Jumper it and shift the truck in reverse with the engine not running(just key in run position) it will display the codes then
  13. #42
    Feb 2009
    Glasgow, Scotland
    159
    There is nothing under my second row? I've got quad captains if that makes a difference?
    Thanks for your reply.
  14. #43
    Mar 2011
    speedwell tn,
    11,884
    Do you have a Escalade esv?(or a ext?)
    If so then it's in a different spot(same module just different location)
    Standard Escalade has the module under the second row passenger seat(the test harness is very close to it)
  15. #44
    May 2010
    231
    Ok I found it finally, it was under the carpet. Her is what the code I got. First both outside lights amber and red light up then the middle amber light flashes 4 times and then the a single red light on the right. Does that mean anything to you?
  16. #45
    Mar 2011
    speedwell tn,
    11,884
    You will need to check the reverse input wiring(likely on the harness panel under the right rear quarter panel) and the driver's side outboard sensor(swap the sensors around and see if the code fallows the sensor if so then it's a bad sensor)
    Also make sure the harness is snug and tight at the module as sometimes a loose connection there can throw the reverse code
  17. Remove Advertisements
