What To Make my EXT Faster!
Results 1 to 11 of 11
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, What To Make my EXT Faster! in Cadillac Escalade Forums; I'm Thinking of headers? But the ones i've seen are Expensive My Trucks a Lease so i don't wanna sink ...
    larry_chip is offline Cadillac Owners Fanatic
    Mar 2003
    172
    My Trucks a Lease so i don't wanna sink 1500 in headers I just want some more HP How much HP will they give me ? if its like 5HP then i don't want them, but if theres a Cheap Set i can Buy & they'll give me alot of HP then i'll take them.
    I'm Thinking of Getting a Chip from SuperChips I've never had a Superchip I've had a few Hypertech's but they dont have a chip out for our trucks, what should i go with?
    I Have a Intake & Exhuast Allready.
    slimm44 is offline Cadillac Owners Enthusiast
    Apr 2004
    WA-VA-USCG
    33
    527
    Re: What To Make my EXT Faster!
    supercharger.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,307
    A good set of long tube headers and high flow cats will give you 20-30, but will cost you 1500-2000 installed, cut 500 off that if you install them, you will still need a programmer, or your computer reprogrammed to get the most from your mods. Because your truck is leased I personally would not put a lot on money in it, unless you waste money like I do, then spend the 8k to 10k and get a supercharger.
    T_Dogg8's Avatar
    T_Dogg8 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade EXT 2003 CTS
    May 2004
    PA
    2,860
    i wouldn't bother if it was leased. save the few thousand you're going to spend on that and a few more thousand and pick yourself up some kind of sports car.
    Sta11ion is offline Awaiting Email Confirmation
    Apr 2004
    Toronto Ontario, Canada
    40
    218
    I have been frabricating a turbo kit for this truck, the most difficult part was frabicating the headers. This is for my friends show truck to promote his company. In my truck its all stock, just mostly cosmetic. Your best bet would be with a supercharger, a boost of 6 psi would be effiecent and you would not need to change the fuel pump or fuel inj just need to modify the bias, change to an adjustable fuel regulator, make sure to get it the kit with an intercooler, also modify the ecm, so you get the correct fuel mixture. Another problem would be the tranny shift points. You would need to modify this as well. For my friend trucks I change the ecm to a sds fuel management control system. So I rewired the whole trucks engines wiring. If you want to go cheap I would get a pulley kit, headers, change the intake advance the timing, modify the ecm, change the exhaust, and you should get 378 h with 404 torque, this is still being generous. To get the full potential like you see advertised you will have to change the cams valve opening and closing.
    outofdablue is offline Cadillac Owners Fanatic
    May 2004
    Philadelphia
    411
    Go with a cold intake system, good exhaust, and reprogrammed ecu. This is probably the cheapest way to get a honest 20-30 HP. Otherwise everything else is a waste of money on a leased truck.
    Mar 2003
    172
    I Have a Cold Air Intake & Exhuast Allready,
    What Do you mean by Reprogram the ECU? Like a SUPERCHIP? or Nelson Programing ?
    Machine's Avatar
    Machine is offline Cadillac Owners Fanatic
    Oct 2003
    Texas
    148
    A custom tune is the most economical way to dramatically increase your HP (handheld or Nelson). I wouldn't invest alot of money in a lease vehicle that I did not intend to purchase at the end of its term, though.
    Jungle George's Avatar
    Jungle George is offline Cadillac Owners Fanatic
    Mar 2004
    Los Angeles, CA
    136
    This will make it much faster and can be removed very easily when the lease is up... or better yet, buy out the lease sell it for more money.
    More info on our 2004 2wd Escalade go to lovecars.com and click on project vehicles, in the Escalade site you will see the dyno sheet showing the HP..
    T_Dogg8's Avatar
    May 2004
    PA
    2,860
    jungle george
    did your grill craft grill have a caddy emblem on it??
    Mar 2004
    Los Angeles, CA
    136
    No it did not, we removed the factory one and used epoxy to install it back in, if you are gentle and warm up the old one you'll be able to remove it with no problems or you can use some fishing wire and cut it out from the shell.
    You can go to Grillcraft.com and see their installation.
    I'll be posting new pictures of the Escalade with it's new show paint job....
    Be on the lookout for it..
  14. Remove Advertisements
