Headlights Starting to fog - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 61
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Headlights Starting to fog in Cadillac Escalade Forums; Yes , that "tube" wire was still connected. There is enough slack that I laid mine face down on a ...
  1. #31
    spirit man's Avatar
    spirit man is offline Cadillac Owners Member
    Feb 2013
    44
    Re: Headlights Starting to fog
    Yes , that "tube" wire was still connected. There is enough slack that I laid mine face down on a microfiber towel which was laying on the bumper.
  2. #32
    Snowboarder is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Escalade AWD 6.0
    Jun 2012
    35
    72
    any ideas on how to disconnect that? I don't have a garage so I need to bring the headlights in my house.
  3. #33
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Snowboarder
    It has a harness connection at the ballast just behind the grille(sliver box you can't miss it)on the radiator support
  5. #34
    delliot's Avatar
    delliot is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade
    Jun 2005
    54
    Well, I tried this today... Mixed results so far. using water with a touch of simple green, it got most of the fog but left behind a few spots of fog on each light. Also, got some water spots...
  6. #35
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by delliot
    Let the sit with the caps off
    If it don't clear up rinse them again with just plain water
  7. #36
    sosatyme72 is offline Cadillac Owners Fanatic
    Automobile(s): '03 Escalade ESV
    Mar 2013
    44
    192
    ok so i pulled out my headlight, do I have to pull off all the bulbs out and the lil silver hid ballast? I see that the wiring runs within the headlights. When I add the water to clear out the
    foggyness would the water run out of all the 4 openings? I just dont want to screw anything up when I do this...thanks!
  8. #37
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by sosatyme72
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=116866"/>
    Just pull out the socket for the drl or turn/running light and pour some water in the housing and work it around and that will clear it up
    Leave the rubber caps off till the housings dry out
    You can add a drop of soup if you want to
    No you don't need to remove the hid ballast wire from the ballast
  9. #38
    Mar 2013
    44
    192
    so just pulls those off, leaving the hid ones in place and not removing them?
    Quote Originally Posted by the cadillac man View Post
  10. #39
    Mar 2011
    speedwell tn,
    11,884
    You can pull either the turn signal/running light socket or the drl socket and leave the hid bulbs still in the housing
    I left all but the drl in when I did mine
  11. #40
    Mar 2013
    44
    192
    really ok,i thought that the inside of those lenses were all open so if you put water through one of the openings it will go throughout the headlights. i guess they are closed up in sections?? But the foggyness is all along the top of headlights which one part is over the hid bulb. Water wont affect it being poured in from the open socket next to it....just making sure, knowing my luck i do it and i'll short something out with water.
  12. #41
    Mar 2011
    speedwell tn,
    11,884
    Mine was the same way the water trick fixed it
    Just do like I said in the previous post and it will clear it up
  13. #42
    LS1-IROC is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2008
    3
    Just did this yesterday on my 02...it worked like a charm. I used windex instead of water though. Dried up crystal clear.
  14. #43
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    I installed these as DRL bulbs. They are very bright and have worked great for 3 months now: http://www.ebay.com/itm/110995759571...witem=&vxp=mtr
  15. #44
    Mar 2013
    44
    192
    ok sounds good guess im just leaving the hid's in as you say...thanks
    you have a pic on how the look on truck?
    Quote Originally Posted by sosatyme72 View Post
  16. #45
    spirit man's Avatar
    Feb 2013
    44
    I have washed my passenger side light out 3 times already. Every time it's humid or it rains, it fogs up. The driver's side stays perfectly clear. I think it's not sealed, but I don't know how to determine that. Should I just go ahead and replace it?
  17. Remove Advertisements
