Headlights Starting to fog - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 61
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Headlights Starting to fog in Cadillac Escalade Forums; Originally Posted by spirit man These are the bulbs I bought. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 I'll have to wait until tomorrow to see ...
  1. #16
    HoustonBussa is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade Base
    May 2013
    Houston
    43
    23
    Re: Headlights Starting to fog
    Quote Originally Posted by spirit man View Post
    I'll have to wait until tomorrow to see ......]
    Does that bulb (or any of the LEDs) require a resistor in order to not error out? Pretty sure I'm going to LED's and waiting 'til I can get some good ones to swap them out with.
  2. #17
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by HoustonBussa
    The only thing the would need a resistor for led bulbs would be the blinker (that or a heavy duty flasher)else you would get rapid flash
    I'll have to wait until tomorrow to see what they look like. Here are some more pics.
    Those look good and are cheap let me know how it goes
  3. #18
    spirit man's Avatar
    spirit man is offline Cadillac Owners Member
    Feb 2013
    44
    Quote Originally Posted by the cadillac man View Post
    I'll take it for a spin some time today. The only problem I foresee is if I have to reverse the polarity and flip the bulb around.
  5. #19
    Mar 2011
    speedwell tn,
    11,884
    True so try it before you put the headlights back in the truck
    If you want to see them on in the truck during the day cover the sun load sensor on the dash with a newspaper or something like that then hit the unlock button on the remote(if the setting is on)
  6. #20
    chacho44 is offline Cadillac Owners Member
    Automobile(s): escalade esv
    Dec 2011
    80
    when you did this did u remove the highs and low bulbs or did u leave them in, please lmk how u did it. Thanks
  7. #21
    spirit man's Avatar
    Feb 2013
    44
    I took all of the bulbs out.
  8. #22
    ROCKETW19 is offline Cadillac Owners Member
    Oct 2012
    16
    damn they look brand new. I actually thought I needed to buy new headlights but found this instead gotta try it this weekend hopefully it comes out like yours
  9. #23
    spirit man's Avatar
    Feb 2013
    44
    Quote Originally Posted by ROCKETW19 View Post
    I was nervous about it. Also, while they were drying out, I left the round plastic covers off so moisture would not seal in.
  10. #24
    Mar 2011
    speedwell tn,
    11,884
    I did the same way
  11. #25
    grayparatrooper is offline Cadillac Owners Member
    Apr 2013
    89
    how do you take off the headlight? Is there a write up i missed?
  12. #26
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by grayparatrooper
    It shows in the owners manual
    But here goes
    Pop the hood
    There are little retaining clips that hold the plastic shroud in place at the top of the radetior and grille(remove these) and lift the shroud out of the way
    On each housing there is a rod at the top and side remove those
    To remove the housings from the area pull the grille loose on the side your working with and the housings will be free
  13. #27
    sosatyme72 is offline Cadillac Owners Fanatic
    Automobile(s): '03 Escalade ESV
    Mar 2013
    44
    189
    so you have to take the grill off to get the headlights off??
    But here goes
    Pop the hood
  14. #28
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by sosatyme72
    Just pop the top half loose it doesn't need removing from the truck
  15. #29
    Dec 2011
    80
    Just finished mine on my esv, what a hella difference. Thanks for the write up, a must do imo
  16. #30
    Snowboarder is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Escalade AWD 6.0
    Jun 2012
    35
    72
    Is everyone leaving the headlight "on" the car when doing this? I removed the headlight via the two rods, took out the bulbs, but there is still a rubber house coming from the bottom of the housing. I'm assuming thats the power cord for the ballast. How is that disconnected?
  17. Remove Advertisements
