2003 Escalade - Battery Light
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, 2003 Escalade - Battery Light in Cadillac Escalade Forums; Red battery light in the upper right hand area of dash stays slightly illuminated when the engine is either on/off. ...
    Travis Goode is offline Cadillac Owners Member
    Dec 2004
    20
    Red battery light in the upper right hand area of dash stays slightly illuminated when the engine is either on/off. The light will become brighter when more accessories are turned on. Battery is new & the alt is putting out the correct charge. Any idea what the problem might be? Thanks.
    jayca is offline Cadillac Owners Member
    Dec 2013
    I have the same thing happening did you ever figure out the issue
    I had the alternator changed and the starter same thing now this morning it went off and now it's on again don't get it
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Check the alternator cable and clean the connections
    wesyder's Avatar
    wesyder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
    Mar 2009
    Eastvale Calif
    1,807
    Bad diode inside alternator
    l8agin is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade, 1996 Impala SS, 2005 Audi A6
    Nov 2012
    Maryland
    19
    Re: 2003 Escalade - Battery Light
    I had this issue until last week. My friend owns a repair shop for large/heavy duty trucks and is working on an oil leak for me. While there I told him about the battery light being always on and all he did was plug in a scan tool and turn it off. If the other suggestions dont work out, maybe give this a try.
    Dec 2013
    Well it went off and now it's back on very dim again. Don't get it this happened with out doing anything I had the alternator changed, the battery and the starter
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by jayca
    Have the charging system tested at a gm dealer as they know more about then most shops
  10. Remove Advertisements
