My OBD II port not working
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, My OBD II port not working in Cadillac Escalade Forums; A check engine light came on, I took it to autozone and they could not get the code reader to ...
    Orlie is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    21
    A check engine light came on, I took it to autozone and they could not get the code reader to power up when plugged inti the port. Any idea why the port is not working correctly. They tried 2 different code readers.
    later
    Orlie
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,307
    Re: My OBD II port not working
    It may have been their readers, the dealership uses a Tech II Tool, when I had my 03' my Snap on reader would not work, but the dealership tool worked fine.
    Lu Scola's Avatar
    Lu Scola is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac Escalade EXT King of Mods
    Jun 2008
    Baltimore, Maryland
    595
    Mine did the same thing at autozone. I went over to advance same again, then I opened the hood and I pulled the ECU fuse I think, then plugged it back in and then it read fine.
    93si's Avatar
    93si is offline Cadillac Owners Fanatic
    Automobile(s): 05 Escalade EXT
    Nov 2005
    Winnipeg,Mb
    32
    147
    I just tried mine with my cheap reader and i got the same thing, no power to the reader...
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,313
    Power to the OBDII port is commonly shared with the cigar lighter or power port. Check the fuse.
    Don't mess with Binky Bear!
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Get the coins out of your cigar lighter, replace the 15A cigar fuse in the underhood fuse block and stop using the cigar lighter as a coin holder
    Seriously though, I see this A LOT!!
    It is not the smartest place to put the thing and it only takes a coin toss to pop the fuse.
    OBD II standards use pin 16 as power in the DLC and pins 4 and 5 as ground. If this fuse blows the DLC will have no power and scan tools will not power up.
    93si's Avatar
    Nov 2005
    Winnipeg,Mb
    32
    147
    Awesome Thanks alot i will check that out...
    1class is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade ESV
    Oct 2008
    Gainesville, VA
    99
    Quote Originally Posted by ewill3rd View Post
    Ewill3rd,
    I am experiencing that similar problem with my OBTII reader also not reading 04' ESV. It works on my other cars.
    http://www.harborfreight.com/cpi/cta...emnumber=94217
    Reading your tip I checked my cig fuse and it was fine. The cig-lighter does not work. I took it to another car to make sure it was not the lighter and it worked. Not sure if I am having multiple problems because both rear doors will not lock and unlock and produce no sound when the front doors activate. I thought when you mentioned the fuse that they may have been on the same line, but no luck. If you have any input let me know.
    Thanks
    Apr 2003
    13,307
    Quote Originally Posted by 1class View Post
    Ewill3rd,
    Thanks
    My Snap On reader worked on all my other GM cars/trucks, it works on my 07's, just would never work on my 03' Escalade.
    Oct 2008
    Gainesville, VA
    99
    hcvone, if the snap on reader did not work then I must not complain about my cheap reader. Thanks
    I went out with my son tonight to troubleshoot. We checked not all the 12vdc outlets had power. Checked fuse and they looked ok. Proceeded to remove the rear passenger door panel (which by the way I before doing it I thought it would be difficult.. it was easy compared to some other vehicles I have worked on.) using a voltmeter checked power to the door lock actuator unit. There are two plugs. The best I can describe the one with the larger gage wire did not have power and any time when activating the locks. The other with thinner gage wire had 12 volts all the time. We removed the actuator and carefully oppened cracked open the case and found a little electric motor like one you would find in small electric toy cars. I used 9-volt battery and was able to activate the little motor. We put the lock-unit back together and using the 9-volt battery was able to activate the door lock. All that works so….we are back to square one.
    Not sure maybe someone else has some input.
    Lu Scola's Avatar
    Jun 2008
    Baltimore, Maryland
    595
    I may have an answer for you about your rear doors. I will check with my alarm guy tommorrow. I know the Esaclades have seperate locking systems from the front and the rear. Actually I have some schematics that may help with the locking problems. I just emailed them to you 1class! Open the attachments and you should see the wiring diagram info. If its not the right one let me know.
    Oct 2008
    Gainesville, VA
    99
    Hey Lu, got it, thanks for the great info it should be helpful to my door lock problem. They point out the wiring color and location of the modules and I plan on check it out later and will post what I find.
    According to info, GM has DATA BUS SYSTEM with no central location for front and back locks systems. Also points out the there is a BCM Body Control Module for the deferent doors triggers. That may be a place for me to start.
    Sorry gang I did not mean expand on the door problem on this thread, while trying to solve the OBDII issue. Not sure if this needs to be another thread. Moderator will let us know.
    Fil
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    So you are saying it powers up, but it won't communicate?
    I don't mess with many aftermarket tools, did you say what tool you are using?
    What kind of response does the tool give you?
  16. #14
    Oct 2008
    Gainesville, VA
    99
    ewill3rd
    yup it is aftermarket not very expensive tool, the link for the tool a couple of post back. It is CEN-TECH CAN OBDII.
    This morning I plugged in the tool, turn it on and then started the car. It took a long time and was very slow and just as before it failed, reporting (failure communicating). So then I turned the car off and powered off the scanner. Started the cycle again this time it acted different, it was very fast in sync and finally gave me a reading . no errors to report which is a good thing.
    Not sure why it took multiple times but it finally worked.
  17. #15
    lotech22's Avatar
    lotech22 is offline Awaiting Email Confirmation
    Automobile(s): '99 DeVille, K&N intake, MSD ign w/8.5mm wires, custom exhst
    Oct 2008
    37
    45
    A posible reason that your OBDII is not working is because you have built in diagnostics. Have you tride pulling the codes from the DIC. Access the diagnostics here---->http://www.aa1car.com/library/2002/us100232.htm
    And then use this to diagnose the DTCs you get here--->http://myweb.accessus.net/~090/dtcobd2.html
  18. Remove Advertisements
