Originally Posted by scott367 You have a completely different problem. I would try to drain all the coolant, then run the car with the coolant flush stuff in it. Then fill it back up with coolant. If that doesn't work, maybe the heater core is bad.
After the car is running for 20 min what does the temp gage read? It might just be the whole engine is not heating up because the thermostat is stuck open. |
It does read warm after 20 mins, but the air is cold. We can't drain it right now with all the stinkin' snow out. DH was thinking of bringing it to work and putting it up on a rack.
The new thing is that it blows, then stops blowing, then blows, then stops. Sounds like a loose wire???
