Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac Escalade Forums > Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
cadillac-escalade
Cadillac Forums: Escalade Oil Change w/photos
Old 10-18-08, 10:19 AM
Patrick7997's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 1997 ETC (sold), 2004 Escalade, 2007 HD Road King Classic
View Patrick7997's Photo Album
Casino Cash: $1145
Admittedly, for some of you, you know how to do this, and it would be a waste of time.
For others, I'm sure you are perfectly happy paying people to do these things.
You guys can move on.
However, if there is anyone here who would like to change his/her own oil, and doesn't know how, and was afraid to ask, keep reading....
Keep in mind, the pictures and descriptions are of a 2004 Escalade AWD, 6.0 liter V8, Vin N... If you're not sure, the 8th character in your Vin is your Engine code.
Now, for me personally, I am capable of sliding under the truck and doing this in the garage. If you feel you need the front of the truck on ramps, by all means, feel free to do that. I did this service and took the pictures with the truck on level ground in my garage. To be honest, the worst part is sliding under the running boards. After you get under there, there's plenty of room. Is it easier on ramps?? Yes. Necessary? Not really.
A few things you will need:
This is looking from the front passenger side into the engine bay. You will see the oil cap. Remove it. You will also need a 15mm wrench, get that handy now too.
You will also need an oil filter wrench (the round thing in the picture), an AC PF46 Oil Filter, and a 3/8ths drive to turn the oil filter wrench.
A note about the oil filter: my owners manual states PF44. However, the AC Website says PF 46. Also, the dealership I bought this from had a PF 46 on it. I presume the PF 44 has been superceded by the PF46. I went with the PF 46. If I'm wrong, please correct me, before I ruin my truck.
You will also need this, 6 quarts of 5w30. I use Mobil One. This is not the time to start another oil thread, so if you want to substitute Amsoil, Rotella 5w40 synthetic, Royal Purple, Wal Mart Super Tech, whatever, feel free.
You also need some kind of oil drain pan. Everyone has their own preferences, and they can be bought in a myriad of designs at auto parts stores. Some prefer a big yellow radiator pan. Bigger is usually better. You can decide that for yourself.
Note, I prefer to do this when the truck is warm. You get better oil drainage. Not that you HAVE to do it warm, but I prefer to...
Now then, lets slide under the truck, I usually go right under the driver's door, and move in. Start looking right down the middle of the truck, somewhat towards the front... You are looking for something like this:
I am basically under my driver's seat, looking towards the front of the truck, and towards the centerline of the truck. You can see there your oil plug, and your oil filter. Don't panic, we're going to get the wrench out now...
Again, that's a 15mm wrench, you can see it there on the drain bolt...
Another quick note: if idiot techs (or more likely, the previous owner) have bunged up, damaged, rounded out, or otherwise abused your oil drain bolt, you may want to get a new one NOW, before you start... That way, when it's time to replace the bolt, you can throw your new one on there.
Some people think that vise grips are what you use to remove the oil drain bolt. NOT true!!! Do the world a favor and use the right size wrench...
Remove that bolt. Turn the wrench counter-clockwise to remove.
Oil will begin draining. Initially, the flow will be very strong, position your drain pan accordingly...
As you can see, that's a gusher....
The flow will slow as the crankcase drains... You may have to move your drain pan, to stay under the flow of oil, so be prepared to do that if necessary.... unless you like oil slicks in your garage...
The flow will eventually be just a trickle or slow drip. If you wait forever, or get a phone call while it's draining, you may actually see it stop completely, although that's not really necessary... When it slows to a trickle, replace your drain bolt.
Now we will replace the filter. You obviously saw the blue thing in the previous pictures... that's your oil filter. If you take your PF 46 out of the box, you will see, that's the blue thing.
In that photo, I have placed the oil filter wrench over the end of it. Ahh, those come in a myriad of sizes. While you are at the parts place buying your oil filter, go ahead and try the ones they are selling on your oil filter, to make sure you're buying the right one, if necessary. They will not care. Everybody does that.
Also, you will see that I have attached the 3/8ths drive to the square end of that. There's also a "six-sided" bolt style thing on the bottom of some... you can do it that way too. I prefer the ratchet handle.
Crank the oil filter off, again, turning counter clockwise. Your pan should be under that. Oil will start coming out when you do this....
It will get loose after a turn or so, and you can finish by hand if you like.
Filter is off. See that metal area above, it's circular?? Where the filter gasket meets the metal?? Make sure that's clean. Also, make sure that the rubber gasket did not "stick" to that... It's rare, but can happen. If it's stuck there, and you spin a new filter on, you will have the dreaded "double gasket", which is to be avoided. That will leak HEAVILY when you start the truck....
It's rare... But it can happen. If yours looks like this picture, you are fine.
Spin the new filter on. When it's hand tight, use the filter wrench again to crank it on maybe another 1/2 turn or so, maybe as much as 7/8ths of a turn, depending on how strong your hands are, and how tight "hand tight" means to you. You are NOT cranking this on until it won't turn. What you are trying to do is seat that rubber gasket, and compress it some. Friends of mine are very cabable of doing it by hand only. When my hands are slippery with oil, I can't do it, I use the wrench. A decent guideline is when the gasket is fully in contact with the mating surface, go 7/8ths to 1 turn from there...
New filter in place. Nice. Make sure it's wiped nice and clean like this, so that if it does leak, you can see that right away...
To review, we have drained the oil and replaced the drain plug. We have replaced the filter, and it is now on tight.
Congrats!! You're getting close. Let's go back up topside.
I like to use a decent size funnel... You can see it there, in the oil fill tube....
Pour your 6 quarts of oil in there....
Remove the funnel, replace the oil cap, start the truck.
Run the truck for 30 seconds or so, and while it's running, check for leaks. You are looking carefully at the oil plug, and the oil filter. You will probably see no leaks.
Shut the truck off and check the oil. For mine, 6 quarts was perfecto, right at the full mark on the dipstick.
Hey, guess what?? You're done!!
This may have taken awhile, and that's fine. After you do it a few times, this can easily be done in 40 minutes...
Now, find some way to enjoy all the money you just saved.
  #2 (permalink)
Old 10-18-08, 10:37 AM
my name is Tiffany
Cadillac(s): 05 CTS-V
View urbanski's Photo Album
Casino Cash: $1133630
Re: Escalade Oil Change w/photos
sweet
  #3 (permalink)
Old 10-18-08, 04:46 PM
jcmendo01's Avatar
View jcmendo01's Photo Album
Casino Cash: $625
Do we have to do anything with resetting the oil change me back to 100%?
  #4 (permalink)
Old 10-18-08, 04:48 PM
JD001249's Avatar
Cadillac(s): 2005 Escalade
View JD001249's Photo Album
Casino Cash: $3650
Awesome. Thanks for the info! I may just have to try this myself, $70+ for an oil change is getting obnoxious!
  #5 (permalink)
Old 10-18-08, 05:32 PM
Cadillac(s): Cadillac Escalade EXT King of Mods
View Lu Scola's Photo Album
Casino Cash: $7350
I change my own oil also. Walmart has the best prices on oil. I buy the 5 quart bottles for 15 and an extra quart for 2.35. The oil filter is under 3.00.
Synthetic is 20 at walmart. I have the Valvoline (SYN Power) Fully Synthetic. My oil changes cost me 25 bucks and 20 minutes of my time.
When done the oil change you can reset the oil life meter by using the buttons on your steering wheel. Its very easy.
Great write up Patrick!
  #6 (permalink)
Old 10-18-08, 06:51 PM
Casino Cash: $1145
Thanks...
That was a good question about the oil life index.
I don't have it in front of me, but press the buttons to bring up the oil life index. If I change mine at 3000 miles, I generally have 50% to 60% oil life remaining....
With the oil life on the screen, press and hold the "return" key, the one with the arrow on it. Same one that resets the average miles per gallon. It's in the lower right of the steering wheel.
Keep holding it. It takes a few seconds, but then the 55% number (or whatever) will turn into "XXX", and sit there.
Some things might start dinging.... the wrench symbol might light up on the dash... I haven't really payed super close attention, but a lot seems to be happening on the dash while this happens. I'm usually just watching the XXX number, waiting for it to be 100...
Don't panic.
As you keep holding that button, eventually the oil life number will become "100%" again... Now you can let go of the button.
And it's reset!
Forgot to mention that, sorry.
  #7 (permalink)
Old 10-18-08, 07:37 PM
Cadillac(s): .
View Spittin Game's Photo Album
Casino Cash: $7535
Great write up!
  #8 (permalink)
Old 10-18-08, 10:21 PM
View dstinson's Photo Album
Casino Cash: $2172
o my... a tutorial on how to change your oil??? (very detailed by the way) What can i expect next, how to change a tire? If you cannot change your oil, I believe we need to start revoking man cards.
  #9 (permalink)
Old 10-18-08, 10:37 PM
Cadillac(s): 2005 Blue Chip Escalade
View ESCALADOR's Photo Album
Casino Cash: $9325
lol!! I agree, I have never had anyone change my oil in my cars/trucks...Well exept when my boy worked for Goodyear and would slide it in for free!!
  #10 (permalink)
Old 10-18-08, 11:12 PM
Cadillac(s): 2008 DTS, 2005 Escalade EXT, 1975 Eldorado
View Bart's Photo Album
Casino Cash: $815
Thats a Roger...Roger.
Here is my oil change tutorial....loosen bolt that looks like oil plug, let drain, remove thing that looks like an oil filter...fill new one with oil...put it on...replace drain plug...fill with oil. 5 minutes later...you are done.
  #11 (permalink)
Old 10-20-08, 09:04 AM
Casino Cash: $1145
Didn't I say at the beginning, if you already know how to do this, you could skip it??
Everyone has a different level of expertise.... Everyone has had different life experiences... Let's not flame people who aren't ASE Certifed Masters...
  #12 (permalink)
Old 10-20-08, 09:26 AM
bigksone's Avatar
Cadillac(s): 2004 Escalade
View bigksone's Photo Album
Casino Cash: $7210
Putting that disclaimer at the beginning was a good idea. I've been changing my own oil for a long time, but I still chose to read the post. I think you did a very good job. The info and pictures should be enough to help a first timer get the job done.
  #13 (permalink)
Old 10-20-08, 10:27 AM
ml05's Avatar
Cadillac(s): Escalade 03
View ml05's Photo Album
Casino Cash: $610
Yes thanks for the post very detailed information! As I have always had guys do my oil change for me I will have to try myself to change my own oil!
Melissa
  #14 (permalink)
Old 10-20-08, 10:47 AM
Cadillac(s): 06 Escalade
View fierodough's Photo Album
Casino Cash: $4340
Why are people knocking this guy's post??
He took the time to take pictures and give detailed instructions. Time he is not getting paid for. If you already know how to change your oil, then good for you. Some people don't and appreciate the effort.
Will you complain if this person works his way up to replacing a head gasket?? Maybe you will need his pictures and how to then.
anyhow, that's my opinion. Thank for your hard work, we appreciate it.
  #15 (permalink)
Old 10-20-08, 11:46 AM
Moderator
Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's
View hcvone's Photo Album
Casino Cash: $3535
Patrick, nice post for the owners who change their own oil, making this a sticky
Carl V.
**Authorized Zaino Distributor **
**Authorized Amsoil Dealer**
Web Site hcvind.com
change, escalade, oil, w or photos
