Answer the 1Million Question: Where is the air ride control relay located? - Page 7
Page 7 of 30 FirstFirst 1234567891011121314151617 ... LastLast
Results 91 to 105 of 436
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Answer the 1Million Question: Where is the air ride control relay located? in Cadillac Escalade Forums; front right signal - 2.70v front left signal - 2.83v level pressure sensor signal - .41v steering position sensor signal ...
  1. #91
    luxurylife33's Avatar
    luxurylife33 is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Escalade (sold) 03 Escalade EXT (sold) - 07 Escalade EXT
    Oct 2008
    Long Island
    29
    1,363
    Re: Answer the 1Million Question: Where is the air ride control relay located?
    steering position sensor signal - 10.9v or 13.6v ... theres 2 light blue wires, dont know which is which
    left rear signal - 2.78v
    right rear signal - 2.68v
    "ignition 3" voltage - .41v (seems low)
    Damping Lift/Dive Signal - 13.31v
    these are my readings
  2. #92
    sk7's Avatar
    sk7
    sk7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade AWD
    Nov 2008
    Québec, Canada
    48
    1,025
    I didn't get into much details when I was looking at the SCM a few weeks ago. The 5 volts ref (gray A9) was ok, A10 lt blue wire trigger negative to the compressor relay works (activates the compressor once it put to ground). Power (org) and ground was present at the GRY Metri-Pack connector. Ignition 3 (brown) should be higher than 12 volts (either at the Lt blu 24 way Micro pack connector) or at the compressor control relay. So that might be something to look at for starters. I hope your truck has enough miles to justify replacing the shocks. I should post pics of the one I removed from the back, they were shot!!!
    I'll need to dig a little further for those reference voltage for the suspension level, solenoid and steering input. You are still getting no error messages and compressor isnt working? I need to get a car outta the shop before tomorrow, will get back to you with the info before Zzzz time.
  3. #93
    Oct 2008
    Long Island
    29
    1,363
    almost at 88k miles.... the rears were SHOT.... the fronts were in good shape so ill just sell em on ebay and try and get some money back, rather have new ones anyways, i plan on keeping the car for a while
  5. #94
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    Here's what I could find in the service manual:
    -Shocks solenoid reference value should be 1.5 - 3.3 Ohms. Didnt say if that would vary with shock fully extended or ? I don't think it would matter.
    -The suspension level indicators are voltage driven, 0.5 - 4.5 Volts signal at the SCM. Disconnected should read 0.5 at the SCM, jumping the 5V ref to to signal circuit should show 4.5V at SCM.
    -Steering wheel input reference is 0.35 - 4.75 volts. It has 2 separate outputs. That sensor is listed in the stabilitrac section tho, so it should not be an issue with the suspension control stuff.
  6. #95
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    Wiring diagram to troubleshoot that IGN 3 input issue...
  7. #96
    Oct 2008
    Long Island
    29
    1,363
    "-Steering wheel input reference is 0.35 - 4.75 volts. It has 2 separate outputs. That sensor is listed in the stabilitrac section tho, so it should not be an issue with the suspension control stuff."
    This may be the problem, your right about the two outputs, they are reading 10.9 and 13.6v at the SCM ...... nowhere near the range they should be... and i have seen plenty of threads with people's steering position sensor going bad, but the said they have a "service stability system" issue and not a "service ride control" issue .... how much is the sensor? if its cheap its worth a shot .... ill have to call the stealership tomorrow....
    edit: btw i appreciate all the help!
  8. #97
    ESKY02 is offline Cadillac Owners Fanatic
    Automobile(s): ESCALADE
    Aug 2009
    37
    201
    K i found the relay, hooked to the front side of my fuse box. The number on it is 1219603. I pulled the relay off, and jumped the red to red wire. All i got was a spark and a click thats it. Now i jump them and get nothing. The "stud 1" fuse is good and the "ign 3" fuse is good. am i doing something wrong?
  9. #98
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    Jumping the 2 bigger guage wires should get the compressor to run. If not its either not getting power (there's a plug on it) or its shot. You can easily remove it, its a few 13mm nuts to take off. You can then try it on the bench with a spare battery.
    I agree those steering input sensors are prone to failure, but it shouldnt mess with the suspension control module. If you get no service stability system message, let's assume all is well there. Did you manage to get 12V at the ignition 3 wire? That would explain why you get no error message, technically the SCM doesn't power up, no compressor activation, no error message either?
  10. #99
    Oct 2008
    Long Island
    29
    1,363
    I have had a "service ride control" message since the problem began.
    On a good note, I fix customers cars for a local car wash (paintless dent/ scratch removal) and he's good friends with a service manager (they use the car wash for all their cars) at a Chevy dealership and says he'll speak to him about my issue and most likely scan it for nothing!
  11. #100
    Oct 2008
    Long Island
    29
    1,363
    I confused tan and brown ... the ign 3 is fine.... the tan i get about .3v when its dumped and if i fill it, i get 1.5v .... is that OK for the leveling pressure sensor voltage range? 1.5v is kind of low still for the sensor, where as the others go up to about 5v, but i could be wrong....
  12. #101
    Oct 2008
    Long Island
    29
    1,363
    From your previous post:
    Does the scan tool indicate that the Air Pressure Sensor data parameter is within the specified range?
    4.8-5.2 V
    hmmmmmm maybe that sensor is bad..... mine read .3 dumped and 1.5 filled
  13. #102
    Aug 2009
    37
    201
    SK7,
    I unplugged the relay to jump the red wires. As soon as i touched the jumper wire from red to red i got a spark and a click thats it. Second time i got nothing. Now what? I had the key to the on position if that makes a difference.
  14. #103
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    Air pressure sensor data? Is that the exhaust solenoid on the compressor? I admit I didnt test that one either!
    ESKY02 - I answered your question a few posts up, If the compressor is short to ground (motor) the big fuse must be shot in the fusebox (after the jump attempt), its the first one on the right if I remember correctly... No need to leave the key in the on position for the test.
  15. #104
    Aug 2009
    37
    201
    wow whos talking to who? im lost hahaha
  16. #105
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    No prob! Do you have a test light? Check to make sure the power wire still has 12V. The compressor does take quite a bit of juice to kick on (not as much as the ECBM motor mind you!). Maybe it was just stiff from not being used. I would replace the fuse (if it is blown) and retry by just touching the contacts together for a split second, see if you can get it to run. If not you will need to remove it for further investigation or replacement.
  17. Remove Advertisements
