Answer the 1Million Question: Where is the air ride control relay located? - Page 18
Page 18 of 30 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 256 to 270 of 436
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Answer the 1Million Question: Where is the air ride control relay located? in Cadillac Escalade Forums; Im not seeing one that says ALC?? I tried pulling the RTD and it gave me a SSS light but ...
  1. #256
    nohopeboyz is offline Cadillac Owners Member
    Automobile(s): escalade
    Nov 2010
    15
    Re: Answer the 1Million Question: Where is the air ride control relay located?
    Im not seeing one that says ALC?? I tried pulling the RTD and it gave me a SSS light but no more service airride?? No What??? Please help I REALLY get erked about this sorta thing.. thanks
  2. #257
    sk7's Avatar
    sk7
    sk7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade AWD
    Nov 2008
    Québec, Canada
    48
    1,025
    Ur right about the RTD. My mistake... The EBCM gets power from one of the maxi fuses, ABS one I believe. If all is ok there post back. Could be a failure of the EBCM, those are troublesome units...
  3. #258
    CaddyEscalade is offline Cadillac Owners Fanatic
    Automobile(s): Escalade
    May 2010
    231
    Quote Originally Posted by fitz13 View Post
    ok, another new member of the forum here after spending much time readung through everyone's problems - and congrats to those who have found solutions to there's...I am still, as well as my dealer, dumb founded with my issue. My compressor was tested and works. Shocks and lines have no leaks. Truck turns on, within 30 sec compressor kicks on, rear lifts...i attach our trailer and rear end never auto levels out...ugh! Any thoughts?
    I would start with removing the relay and jumping the wires to see if the compressor starts up if so, then try the jumper again with a load on (trailer hooked up) and see if it still comes on and lifts. If you start from the beginning on this thread it will give details on jumping the wires to test it out.
  5. #259
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    Fitz13: The only reference for the SCM to command the compressor on is thru the back level sensors. Did you buy this truck new? Has it been lowered? Hooking up a trailer, passengers getting in the back, filling up the tank, even hard acceleration will cause the compressor to turn on and level out the back end. My guess would be that the level indicators are working at the low end of the 0-5V reference. Your dealer can verify this data with their Tech2 scanner. If there was an electrical problem with the compressor, the SRC light would come on after you hookup a trailer. Btw welcome!!!
  6. #260
    Nov 2010
    15
    pULLED RTD FUSE GOT SSS LIGHT STILL?? MY COMPREESOR NEVER WORKED AND MY SHOCKS HAD HOLES IN THE BAGS AND I DIDNT GET THE SERVICE RIDE CONTROL UNTIL I REPLACED THE REAR SHOCKE WITH GAS SHOCKS.. tHIS DAMN LIGHT WILL NEVER GO AWAY.. ANY SUGGESTIONS
  7. #261
    wine1959 is offline Cadillac Owners Member
    Automobile(s): 2003 Escalade
    Dec 2010
    Port St. Joe, FL
    57
    12
    After reading all the threads about ride control system problems, I was able to fix mine in less than two hours, thanks everyone who posted their comments. In the end my problem was the coil wire had broken on the exhaust solinoid. Solidered it back and the system works like new.
    The ride control relay on a 2003 Escalade IS located under the fuse panel under the hood.
    Thanks again to everyone who spent hours working on this problem.
  8. #262
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    Thanxs for the update! This solenoid should have been more protected from moisture. I sealed mine off with lotsa silicone after soldering the two wires. Been over a year since the fix and still works great.
  9. #263
    ALAALDEAN is offline Cadillac Owners Member
    Automobile(s): ESCALADE EXT 05
    Dec 2010
    40
    7
    I would like to thank everyone how participated in this thread I was having this problem for almost 2 years if not more? I t was the exhaust solenoid the white wire broken and it was not open circuit when checked? But still I decided to open it after soldering it everything worked fine .thank you thank you thank you.
  10. #264
    GaExt's Avatar
    GaExt is offline Cadillac Owners Member
    Automobile(s): Escalade EXT
    Sep 2010
    16
    Hello to everyone who have post on this thread i have read through all 18 pages cause i have somewhat of the same problems. My 03 ext has a src but i can hear my compressor turn on everytime i turn on my truck,the src pop up soon as it start driving. so could it be something else or can it still be inside of the compessor that the problem.Also mine didnt start coming until my wife drove home on a almost complete flat tire since she wasnt far from the house and it hasnt gone off yet (3wks now).Could it be the scm need to be reset.Thanks to any advice in advance.
  11. #265
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    Welcome GaExt! There is a code that will trigger the SRC error message if the compressor runs for a set time without any change in the ride height/pressure. How long does the compressor runs for? Does the back end raises up? If run time is reasonable, say 20-30 seconds, the pressure sensor or level indicators are probably faulty. At least you know the solenoid is ok lol! Post back ur results.
  12. #266
    GaExt's Avatar
    Sep 2010
    16
    yes the compressor comes on for about 8 -10 sec and yes the back end seen to raise up.but soon as i put in gear the src light pop up.
  13. #267
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    I would guess the two rear level indicators are not sending the same values to the SCM. Do you have a good digital multimeter? First check to see if the level indicators are not broken, or rods bent (rear inner wheelwell, towards the front, cant miss em). Did you fix the flat tire yourself? Maybe the level assembly was damaged in the process. If all is well you will need to measure the voltage at the SCM before and after compressor run time. Same for pressure sensor indicator.
  14. #268
    bhopt2003 is offline Cadillac Owners Member
    Jan 2011
    17
    is there a pic of this relayu anywhere!!!!
  15. #269
    Trombly92 is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac de Ville
    Jan 2011
    Seattle, WA
    25
    5
    Yeah pics would be nice
  16. #270
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    You will find pics of the relay for the compressor somewhere in this thread. Its attached to the harness going into the underhood fusebox.
  17. Remove Advertisements
