Answer the 1Million Question: Where is the air ride control relay located? - Page 12
Page 12 of 30 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 166 to 180 of 436
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Answer the 1Million Question: Where is the air ride control relay located? in Cadillac Escalade Forums; Originally Posted by pearl04 My escalade had a C0660 body code from the service ride message (Exhaust Soleniod). Replaced my ...
  1. #166
    luxurylife33's Avatar
    luxurylife33 is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Escalade (sold) 03 Escalade EXT (sold) - 07 Escalade EXT
    Oct 2008
    Long Island
    29
    1,363
    Re: Answer the 1Million Question: Where is the air ride control relay located?
    Quote Originally Posted by pearl04 View Post
    My escalade had a C0660 body code from the service ride message (Exhaust Soleniod). Replaced my compressor with one from Arnott, it is considerably quieter than factory. If you use "74V4-W7D" as your coupon code on Arnott's website it will give you 10% your order.
    DAMMMMMMMMIT I bought 2 front shocks 2 rear shocks and a compressor from them! That's about $100 I could have saved.... SHIT
  2. #167
    auberypn is offline Cadillac Owners Member
    Automobile(s): escalade ext 2003
    Nov 2009
    29
    thanks guys,i replace the compressor (arnott) it works great, but service ride control still appears,iguessed i will have to disconect the scm and see if i get i different reading.You guys are indeed the true tecnichan,without these tread people will have to spend o lots of $$$$$$ to get things fixed. I appreciate sincere! thanks once again
  3. #168
    Nov 2009
    29
    Sorry sk7 my computer was giving me some problem so i was unable to respond ,but like i said i changed the compressor ,and is now checking at the sensors. Thanks ! and these post are so long that i do gorget which page i am on,is hard to keep up.THANKS.
  5. #169
    sk7's Avatar
    sk7
    sk7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade AWD
    Nov 2008
    Québec, Canada
    48
    1,025
    No prob! How long does the compressor run for when truck is first started in the morning? Does it come on randomly afterwards while u drive? When exactly does the SRC message appear? Always the same pattern? Checking the 5V reference for the 2 rear level indicators and pressure sensor would be a good place to start.
    After a few coooold ones I do become a good technician lol! Problem is no one else shares my opinion at that point... I believe was are a bunch of handy DIY guys who won't put up with paying high $$$ to have someone service our trucks. Strenght in numbers, this site should be sponsored by cadillac!
  6. #170
    Nov 2009
    29
    WOW! i think pay will be negotiated. I dont know where to check for the position sensor or the pressure sensor,i spend sometime today looking to see if i can come up with something to have the src light disappear,but like its a good relationship until it gone bad. Could u tell mewhere those sensors are located. I WAS THINKING TO TAKE IT TO A DIAGNOTIC CENTER TOMOROW! PAY ABOUT 40 BUCKS,and see if tey come up with something. if the response is early ,i will check in before going.i appreciate sk7. thanks. Remember i now have the arnott (works great)shortly after turning on the ignit, the light appear
  7. #171
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    There's only 3 possible codes for the auto leveling suspension. I pretty sure I posted the diagram for the plug at the SCM, I think its under the rear seat in the EXT. I would try and save my $$$ for a diagnostic readout as much as possible (yes I'm cheap!). Did you connect that bypass for the sensors that came with ur shocks? If you didnt then the 5V reference is no longer there and you will get an error message from the SCM. There's a solenoid in the OEM shocks that is controlled by the SCM that vary the damping according to road conditions (readout on speed, yaw sensor, steering input, and level sensors). This device is not in the Arnotts replacement shocks, so you need to fool the SCM into thinking that all is well with the solenoid.
  8. #172
    Nov 2009
    29
    Being in the natural world is good,but things are sometimes complicated and need further knowledge,but i am intent to learn. My arnott shocks cost 479 bucks,compressor 179,plus shipping did it all by myself,compare to the dealer i am still way ahead,so tomorow i am going to attemp your solution,hopefully is the same thing we are talking about.! I discover the scm but dont have a clue in electronics,or wireing,but would appreciate any idea,to get me off that message, i will have to know how the system works so i can apply the very priciple u have outlined!. Should i start with the wire from the relay (disconected) and take it direct to the scm with wire unplug,agood way to start for me,then i will procede. I WANT TO BE OFF COURSE FOR AWHIL,I GOT SOME SYNTEC MOTOR OIL FOR FREE AND CHANGED MINE TODAY DO U KNOW HOW TO RESET THE PERCENTAGE OF THE OIL FOR READING 100%.THANKS!. And dont forget cheapnis comes from within.
  9. #173
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    The reset for the oil is done with the key on and pressing the gaz pedal to the floor so many times in less than 5 seconds. At least that's how it is on my 02, could be different on the 03 and up. Owners manual should point that out.
    You will need a digital multimeter to read 5V reference at the scm. But maybe you won't need to. So you got a new compressor and new shocks in the back installed, and the compressor still doesnt work automatically and you get a SRC message? The compressor has never worked since the install?
    Its a good thing to try and work things out by yourself. With a few basic tools, a bit of help from this forum, and patience, you'll figure it out! And it's rewarding to know how the system works for future breakdowns...
  10. #174
    Oct 2008
    Long Island
    29
    1,363
    On the 03+ use the steering wheel controls to get the oil % to show. With the % showing, press and hold the "enter" or arrow looking button for about 5 seconds (until it resets to 100%).
  11. #175
    Nov 2009
    29
    You guys are terriffic,i will attemp it again today if giving the oppertunity to do so,but i will keep u posted of the outcome,i think something is going to work out,determency would be challenge,so gold completed.Thanks once again. You wouldnt beleived something i am in a mechanic shop (body work) and the guys like me dont have a clue.
  12. #176
    Nov 2009
    29
    Thanks for the help with the oil %,thats fine,i will try and see about the src this weekend GM wanted $98.00 to $144.00 to do the diagnostic,but money is hard to find. I keep u posted. Thanks!
  13. #177
    Nov 2009
    29
    Back once again! i think i will have to get a diagnostic done,my src was on for to a longggggggggg time, and i remember i was told by strutmaster that it would affect the front eventualy, mine looks a bit shady,and would have to make a decision wether to pay gm price or to just get a pair of front,and hope it diss,.appear. oil reset was a success.Thanks
  14. #178
    pearl04 is offline Cadillac Owners Member
    Automobile(s): 04 Escalade
    Jan 2009
    32
    Quote Originally Posted by sk7 View Post
    Originally had C0660 code...Replaced compressor with one from Arnott, everything went well, no service ride control, etc....Noticed the rear shocks were leaking pretty bad so I ordered a set from Arnott, installed 2 nights ago and now I'm getting a service ride control message again....The shocks I received from Arnott did not have any type of "bypass" for my shocks????
  15. #179
    sk7's Avatar
    sk7
    Nov 2008
    Québec, Canada
    48
    1,025
    Is there a spot on the Arnotts to plug in the wire for the solenoid control? Its a 3 wire plug.
  16. #180
    Jan 2009
    32
    yes the factory plug, plugs into the Arnott shock
  17. Remove Advertisements
