Easy way to change front turn signal bulbs??
Results 1 to 3 of 3
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, Easy way to change front turn signal bulbs?? in Cadillac Escalade Forums; Ordered some chrome turn signal bulbs but I can't figure out how to get to the bulb? Could someone walk ...
    i300zxtt is offline Cadillac Owners Member
    Mar 2004
    11
    Ordered some chrome turn signal bulbs but I can't figure out how to get to the bulb? Could someone walk me through? (2004 Ext)
    pimp-cadi-danny's Avatar
    pimp-cadi-danny is offline Cadillac Owners Fanatic
    Automobile(s): 03 ESCALADE EXT,03 HUMMER H2
    Dec 2003
    SO CAL
    43
    226
    Re: Easy way to change front turn signal bulbs??
    email me at my88iroc@yahoo.com i'll try to walk u through it
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,307
    Remove the radiator shroud cover, it is held on with plastic fastners, a small screwdriver will pop them up, remove the bolt (i think it's 9mm), this is all that holds the grill on, once the bolt is removed, gently pull the grill toward to front of the truck about 1-2 inches, then pull upward, the grill has tabs that fit into a slot, the grill will lift out. Now you can get to the headlights, they are held in with long pins, I forget if there are 1 or 2 per light assy, the light assy will lift out and you can get to the bulbs, it will take some time the first time you do this, after that you can do this in a few minutes.
