??service Stability System Light..with Sound??help
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, ??service Stability System Light..with Sound??help in Cadillac Escalade Forums; Hey I have a 2002 escalade and apon driving , i hear and feel a buzzing/humming sound coming from the ...
    getlade247 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    May 2008
    86
    Hey
    I have a 2002 escalade and apon driving , i hear and feel a buzzing/humming sound coming from the front of vehicle when i reach 10km...then the service stability light comes on right after...does anyone have any ideas what it could be??
    ps the sound buzz'z 2 - 3 times before light come on...
    thanks a million
    wisco919 is offline Cadillac Owners Member
    May 2008
    6
    Re: ??service Stability System Light..with Sound??help
    I do not mean to walk on your thread Getlade but I have just gotton the same alarm in my '02. I do not have have any related noises but was wondering if there is a coomon source for the fault. I will be putting the machine on a diagnostic this evening to try and find the fault codes. Thanks in advance!
    cadillacroadside is offline Cadillac Owners Fanatic
    Apr 2008
    new jersey
    314
    pull a code before you take advice or jump to any conclusions, the stability light came on for a reason let the computer start the diagnosis for you
    May 2008
    6
    Took the truck into the stealership to get her serviced and get to the bottome of the Stability Fault issue. I noticed that the right half of my upper brake light was out so I figured I should just get everything checked out and hope for another 40k of faultless miles. I will update with the cause of the fault when I hear back. Thanks for the advice.
    May 2008
    6
    Well it turns out to be a bad Steering Wheel Position Sensor. Simple but semi pricey fix.
    May 2008
    86
    hmmm ive done some research and that seems to be the most common problem wisco919...still dont know what mine is yet...i know for sure that my stability system is not engaging. Now along with the noise ( when i first start off driving) i can feel it in my foot pedal as well, and the truck seems to be held back untill the buzzing noise goes away. Then the light comes on. this all happens before i get to 40km. The sound seems to be coming from the firewall area near my knees..i hope someone has some ideas..one more thing does anyone know how to pull codes on a 2002 escalade?
    thanks guys!!!
    agapeEscalade is offline Cadillac Owners Member
    Automobile(s): Escalade EXT
    Sep 2010
    34
    Quote Originally Posted by getlade247 View Post
    thanks guys!!!
    Have you got a chance to fix this problem? Was this steering wheel position sensor as well?
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    the steering wheel position sensor is the most common fault in these situations, so if you want to just go throwing parts at it then that's a good bet, but like cadillacroadside said in post #3 get the codes first, that will point you in the right direction
    sk7's Avatar
    sk7
    sk7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 Escalade AWD
    Nov 2008
    Québec, Canada
    48
    1,025
    Another troublesome EBCM module? Did you get the trouble codes?
    Reg23 is offline Cadillac Owners Member
    Sep 2009
    51
    15
    Don't mean to bump an old thread, but I figure it would be better than creating a new one for the same issue. I'm having this problem, when the car starts I get the buzzing/grumbling vibration for 5-6 seconds, a few times, before it stop and the service stability system light goes on. In the past I used to hear that sound once in a while but not very often. Like someone else mentioned, touching the breaks interupts the sound.
    Mechanic said it would probably cost about 3 grand. I know a lot of people have mentioned that it's an expensive fix, though it also seems like there are a few possible causes. Assuming it's something that is indeed expensive, should I assume it's nothing I can try to find parts for and handle myself? I don't have much experience with cars but everyone has to learn sometime, right.
    www.BestBailBond.Net is offline Banned
    Automobile(s): NONE
    Aug 2011
    13
    I have This Same Problem, With my 2002 Escalade EXT
    Hit Post Without finishing... I have this SAME Issue EXACTLY as Described atop of this Thread... Upon Starting the 2002 Escalade EXT Up it is FINE. You can go until you hit about 8-10mph You will Hear a Buzz about 2-3 times and almost bogs down for a
    second or two until the Buzzing goes away.. usually 2-3 buzzes about a second each.. When the Buzzing stops; The SERVICE STABILITY SYSTEM Orange Light comes on in the message Center.. This Light will Stay on until I turn the truck off.
    It CONSISTENTLY Does This... Dont Understand Why, I Hope it Is Not Serious.. But Iam Afraid it may Get Worse...?
    Was Thinking about taking it to a Shop have them look at and Diagnose It...
    Not sure What to do.. I dont Have loads of $$ to spend..
    But IF I DO NOT Address this ASAP Will it become Worse... and More COSTLY?
    pouncykt is offline Cadillac Owners Member
    Jul 2012
    4
    My 2002 does the exact same thing too. It's been going on for about two yrs now and I've learned what speed allows me to coast through the stall and barely feel it. I tried to get it fixed but the dealership changed a switch charged me around 400 then says the BMV will need to be replaced for another 3000.00. So upset it wasn't fixed I just gave up and is hoping it doesn't cause more problems. I just don't want to pay the 3000 and that doesn't work. Otherwise my truck runs just great. Surprisingly no one on hear states that they had it fixed and what exactly. Waiting to know for sure and then I will pay the cost. Luv my truck
    Jul 2012
    4
    Has anyone on here actually had this problem corrected?
  16. #14
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Have you tried turning the stability system off and see if the problems continue if not it may be a wheel sensor.
  17. #15
    Jul 2012
    4
    Quote Originally Posted by the cadillac man
    I didn't know it could be turned off. Will check into that. Are u referring to the sensor that was on the stem for the tire? I'm sure if u r talking about this but when I put back on the original wheels they didn't put in the sensors. I had 24s on it and they took them and sat the truck on bricks. That happened twice. Could that have damaged something? Thanks for ur response.
  18. Remove Advertisements
