??service Stability System Light..with Sound??help - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Like Tree1Likes
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, ??service Stability System Light..with Sound??help in Cadillac Escalade Forums; Originally Posted by pouncykt I didn't know it could be turned off. Will check into that. Are u referring to ...
  1. #16
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by pouncykt
    I didn't know it could be turned off. Will check into that. Are u referring to the sensor that was on the stem for the tire? I'm sure if u r talking about this but when I put back on the original wheels they didn't put in the sensors. I had 24s on it and they took them and sat the truck on bricks. That happened twice. Could that have damaged something? Thanks for ur response.
    The sensors I am talking about is in the wheel hubs it has nothing to do with your tire pressure monitoring system
    The switch is on the dash far right and it has a car with lines behind it next to the park asset switch.
  2. #17
    pouncykt is offline Cadillac Owners Member
    Jul 2012
    4
    Quote Originally Posted by www.BestBailBond.Net
    I have This Same Problem, With my 2002 Escalade EXT
    Hit Post Without finishing... I have this SAME Issue EXACTLY as Described atop of this Thread... Upon Starting the 2002 Escalade EXT Up it is FINE. You can go until you hit about 8-10mph You will Hear a Buzz about 2-3 times and almost bogs down for a
    second or two until the Buzzing goes away.. usually 2-3 buzzes about a second each.. When the Buzzing stops; The SERVICE STABILITY SYSTEM Orange Light comes on in the message Center.. This Light will Stay on until I turn the truck off.
    It CONSISTENTLY Does This... Dont Understand Why, I Hope it Is Not Serious.. But Iam Afraid it may Get Worse...?
    Was Thinking about taking it to a Shop have them look at and Diagnose It...
    Not sure What to do.. I dont Have loads of $$ to spend..
    But IF I DO NOT Address this ASAP Will it become Worse... and More COSTLY?
    Did you get this problem looked at yet?
  3. #18
    Mar 2011
    speedwell tn,
    11,884
    Most likely it's the wheel speed sensors.
  5. #19
    Je357 is offline Cadillac Owners Member
    Automobile(s): Escalade
    Sep 2012
    Lond island NY
    35
    61
    Re: ??service Stability System Light..with Sound??help
    I have the same humming noise with the service stability light on ass well..but when i let off the gas ,the humming goes away...get on gas humming is back..did u fix this problem?
  6. #20
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by Je357
    I said the fix in a post on this thread it is a wheel speed sensor.
  7. #21
    codyt03 is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade
    Jun 2013
    32
    So my 02 does the same thing, exactly. has anyone got a fix yet? If i turn off the stabilitrak it still happens
  8. Remove Advertisements
