  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac Escalade Forums > Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
cadillac-escalade
Cadillac Forums: Need battery help!!!
Old 03-31-08, 09:27 PM
Cadillac(s): Cadillac
View BlakSpyda's Photo Album
Casino Cash: $790
I just went through my 3rd factory AC Delco battery. I don't have anything special hooked up, just an aftermarket Clifford alarm system. I am about to upgrade my 03 EXT w/ an Optima! I drive my Lac Mon-Fri on the regular. Usually on the weekend it doesn't get as much action. Which battery should I purchase from Optima to fit my driving routine...the RedTop or YellowTop?
  #2 (permalink)
Old 04-01-08, 07:45 AM
Cadillac Owners Master
Cadillac(s): 2010,2009,2008 Escalade's, 2008,2006 SRX's
View hcvone's Photo Album
Casino Cash: $3240
Re: Need battery help!!!
Red Top, I have replaced many Delco batteries, probably over 20 that failed, and I only keep my cars/trucks for a few years, never had issues after replacing the stock Delco's.
  #3 (permalink)
Old 04-01-08, 01:25 PM
Guyz1996deville's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2003 Escalade
View Guyz1996deville's Photo Album
Casino Cash: $1202
There is not a valid reason why you should be having to replace like that. I would check continuity on your hot terminal to the ground. You might be shorting to ground and cooking plates. You might want to check the voltage on the terminals when you are running. For some odd reason you might not be regulating voltage properly. If you are overcharging your battery it is bad for it too....
  #4 (permalink)
Old 04-01-08, 02:12 PM
Casino Cash: $3240
The dealer replaced my Delco battery in 03' twice, once it died, and once the terminal just starting leaking out acid all over my garage floor, this was within 1 month, so weird things do happen.
  #5 (permalink)
Old 04-06-08, 01:07 AM
Casino Cash: $790
Thanks
  #6 (permalink)
Old 04-06-08, 07:41 AM
silversport's Avatar
Cadillac(s): 2000 Escalade
View silversport's Photo Album
Casino Cash: $2596
I have always had good luck with A/C Delco batteries but I might look for other problems with your set up...good luck with the Optima...
Bill
Tags: ,
battery
attach your bluetooth cell phone to onstar
flash wax for your cadillac
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum
