| Re: Steering Issues, Please Help Newbie that could very well be your problem, there has been a few bulletins on this situation, if you are turning on dry pavement and it feels like the vehicle is dragging your viscous cluth might have unwanted apply, if you suspect this the this to do is change your transfer case fluid to the new autotrac fluid, drive seven to ten times in a figure 8, drive normal for a few miles and see how it worked for you. if it seemed to get better you might have lucked out, most times the clutch will eventually need to be replaced |
