| Re: HOw do you remove the battery? want to move it to left side Should be clamped on the bottom toward the inside of the engine bay, there is a bolt thru a rubber block that holds the battery, a socket with an extension will remove the bolt, they the battery will lift out, you will need a way to hold it on the other side, that is the hard part, but if I remember correctly there is a plate on the side with the air box that could be drilled and tapped to hold the battery, it will take a little work but anything can be done
__________________ Carl V.
**Authorized Zaino Distributor **
**Authorized Amsoil Dealer** Web Site hcvind.com |
