Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac Escalade Forums > Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
cadillac-escalade
Cadillac Forums: No rear heat....Any ideas??
Old 02-25-08, 11:29 PM
Cadillac(s): Cadillac
View renegade34's Photo Album
Casino Cash: $615
I have an '06 Escalade and the rear heat dosen't work.Only cold air comes from the rear vents when the heat is cranked.Any suggestions?
  #2 (permalink)
Old 02-26-08, 01:52 AM
Cadillac(s): 06 Escalade, 99 Deville
View 2caddyjoe's Photo Album
Casino Cash: $1425
Re: No rear heat....Any ideas??
Make sure that you have the overhead consol controls in the front are set aux if you are trying to use the rear controls. Other wise use the front to set the temp and blower.
  #3 (permalink)
Old 02-27-08, 02:03 AM
Casino Cash: $615
I tried that and the vents are blowing cold air even when it is cranked to heat.Any other ideas?Is the rear its own independant system? Ie.heater core, ect. or does it feed from the main (front) system?
  #4 (permalink)
Old 02-27-08, 08:35 AM
silversport's Avatar
Cadillac(s): 2000 Escalade
View silversport's Photo Album
Casino Cash: $2596
I have this same issue with my '00 Esky...are we sure there is a rear HEATER...a buddy that has a Suburban and a Tahoe both with rear air conditioning told me...it's only air...not heat...this could be the answer then...thought he was pulling my leg...
Bill
  #5 (permalink)
Old 02-27-08, 09:44 AM
Moderator
Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's
View hcvone's Photo Album
Casino Cash: $3510
I am pretty sure that all 03's and probably 02's and up have both rear AC and rear heat.
Carl V.
**Authorized Zaino Distributor **
**Authorized Amsoil Dealer**
Web Site hcvind.com
  #6 (permalink)
Old 03-04-08, 12:31 AM
Casino Cash: $615
C'mon guys,somebody must be able to answer this.
  #7 (permalink)
Old 03-04-08, 12:47 AM
250motorsportz's Avatar
Cadillac(s): Cadillac Escalade, CTS on 20's
View 250motorsportz's Photo Album
Casino Cash: $4515
I have the same problem, my 2nd and 3rd row used to get heat and then all of a sudden I tried to use it once and all that came out was cold air.
  #8 (permalink)
Old 03-04-08, 01:28 AM
View Max-Q's Photo Album
Casino Cash: $6185
I had the same problem with my 03. I don't have a clue as to how or why it started working again but believe or not it started immediately after I put in a new battery. I don't know if that had anything to do with it but it didn't work for almost an entire year then it worked the same day the battery was replaced.
I'm wondering if the rear heat is electric and maybe there wasn't enough juice to run the heater?
  #9 (permalink)
Old 03-28-09, 03:19 AM
Cadillac(s): ESCALADE
View BIGTAIL's Photo Album
Casino Cash: $300
I have the same issue - any thoughts on a fix? LAne
  #10 (permalink)
Old 03-28-09, 09:29 AM
Cadillac(s): Cadillac Escalade-2003, 1999 Seville sls
View oldworld's Photo Album
Casino Cash: $2835
Obviously, there is rear air and HEAT. Anyway, I had a similar situation when I purchased my truck in the winter. IT WAS COLD AIR ONLY. Took it back to dealer and they told me it was a relay.
Someone else suggested here about a battery disconnect. That seems to set and reset alot of issues. Wonder if its a good idea to do that once in a while.
  #11 (permalink)
Old 10-12-09, 04:47 PM
Cadillac(s): Escalade
View bigdady1285's Photo Album
Casino Cash: $275
I went to the dealer today for the sme issue and they told me that the Door Actuator and rear HVAC Control Module need to be replaced est. $505.00.
  #12 (permalink)
Old 10-12-09, 05:20 PM
nathanjax's Avatar
Cadillac(s): 04 Escalade 6.0 AWD
View nathanjax's Photo Album
Casino Cash: $3070
Originally Posted by bigdady1285 View Post
I went to the dealer today for the same issue and they told me that the Door Actuator and rear HVAC Control Module need to be replaced est. $505.00.
Change it yourself... (stealing pics from another site)
heres what the heating unit looks like. It's on the right side in the rear...
1- Hot/Cold actuator
2- Floor/Ceiling actuator
3- Control module #15832319 with the two blue clips
Looks like you need part #1
  #13 (permalink)
Old 10-13-09, 08:36 AM
Casino Cash: $2835
GREAT PICS as always!
  #14 (permalink)
Old 10-13-09, 10:50 AM
Cadillac(s): 04 ESV PLATINUM
View bigdaddy's caddy's Photo Album
Casino Cash: $2170
Cool Re: No rear heat....Any ideas??
I had the same problem with my 04 I reset the blend door acuators and it has work so far for me Turn the truck off In the under hood fuse panel there is a fuse marked HVAC/EACS pull this fuse for about 20 seconds Reinstall fuse and start up the truck do not touch the heater controls and the acuators should reset them selfs in a few mins. This is what i did and so far so good This is something to try befor replacing parts Hope this helps
  #15 (permalink)
Old 10-13-09, 12:20 PM
KrazyKeith's Avatar
Cadillac(s): 03 Escalade
View KrazyKeith's Photo Album
Casino Cash: $3545
I'm going to give this a try before pulling apart the truck to replace the actuator/s and or control mod. I would think its just the one actutor in my case. A reset may help though, worth a shot!
Tags: , ,
heatany, ideas, rear
