do 99 escalade wheels have the same bolt pattern as 03 wheels
Results 1 to 11 of 11
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, do 99 escalade wheels have the same bolt pattern as 03 wheels in Cadillac Escalade Forums; im looking at a cheap set of 99 escalade wheels/tires for just a winter set, and i need to make ...
    03 blk 6.0's Avatar
    03 blk 6.0 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    washington
    16
    Questiondo 99 escalade wheels have the same bolt pattern as 03 wheels
    im looking at a cheap set of 99 escalade wheels/tires for just a winter set, and i need to make sure the 99 wheels will fit a 03, same bolt pattern??, i am asumming they are but want to make sure, they are only $130 for a set of 4 and 25% tread left
    silversport's Avatar
    silversport is offline Cadillac Owners Enthusiast
    Automobile(s): **2014 CTS4 Sport Wagon-Luxury**Gone-2000 Escalade**2008 SRX
    Nov 2007
    ChicagoLand, USA
    797
    Re: do 99 escalade wheels have the same bolt pattern as 03 wheels
    Well...I have a 2000 (same wheels as you're talking about) and have added 2007 wheels...I have seen 2000 Escalades with 2003 wheels...if the fit ours...ours must fit yours...I hope more chime in with help.
    Bill
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,289
    They should be the same pattern.
    Daryl in KY's Avatar
    Daryl in KY is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade
    Jan 2004
    Western Kentucky
    65
    159
    The bolt pattern and offset are the same. However, the brakes have changed. You can put newer 17" and larger wheels on the '99 & '00 lades, but the '99 & '00 16" wheels probably won't fit the '02 and up vehicles with the larger brakes.
    Synergetic's Avatar
    Synergetic is offline Cadillac Owners Connoisseur
    Automobile(s): 02 ESCALADE
    Apr 2005
    CALIFORNIA
    1,529
    Yes, be sure they can clear your newer brakes. If they're local, maybe test fit them. I ran into this problem a few years ago, although my problem was clearing my over sized after market rotors. If they fit properly, then you might have found yourself an OK deal.
    03 blk 6.0's Avatar
    Nov 2007
    washington
    16
    yeah i bought them and they dont fit the rear, they fit the front fine it also seems that the wheel studs are smaller because the lug nuts the guy included were to small, do they only fit 99 escalades or do they fit like suburbans and yukons??
    Jan 2004
    Western Kentucky
    65
    159
    The '99 & '00 Lade/Denali wheels will fit the the older year vehicles that came with 16" wheels. When GM chaged the rear brakes, which was much needed, they had to go to 17". The change didn't happen across all of the 1/2 ton platforms at the same time. The '00 Tahoe with the new body style went to the new brakes. I'm not sure when the pick-up changed. The studs on your '03 are14mm fine thread.
    TSS's Avatar
    TSS
    TSS is offline Cadillac Owners Connoisseur
    Automobile(s): 07 Lade & 06 SRX (Gone); 2010 Enclave CXL; 2010 MKS Ecoboost
    Jun 2006
    3,673
    Quote Originally Posted by Daryl in KY View Post
    My 01 Tahoe LT had 16" rims, as did all 01s except the Z71, which had 17s.
    So, maybe the brake change was later, not right at the start of the "new" body style. Regardless, the 99/00 Lade wheels will fit 99 and older Tahoes and Suburbans as stated by Daryl.
    ct1054 is offline Cadillac Owners Member
    Automobile(s): 2010 Cadillac Escalade
    Feb 2011
    34
    7
    the best reference to use onlne is bigwheels.net
    Hawk-TDZ's Avatar
    Hawk-TDZ is offline Cadillac Owners Member
    Automobile(s): 2004 Escalade ESV Platinum, 2007 Excalade EXT
    Jan 2011
    Ontario
    42
    26
    I think part of it too is the offset of the rim, beccause they come with 16" spares that do fit
    JERRYMCGOVERN is offline Cadillac Owners Member
    Automobile(s): 79 Cadillac, 2003 Cadillac and Mercedes 300TE
    Feb 2008
    Buellton CA
    74
    10
    I am trying to get the Escalade lower to get into the vehicle. Will the 16' wheels help to lower the ride???
  14. Remove Advertisements
