escalade 2002 URPA
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, escalade 2002 URPA in Cadillac Escalade Forums; I have a problem with my URPA it doesn't work. An i just replace the rear sensors with some new ...
    kenneth.dk is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2007
    7
    escalade 2002 URPA
    I have a problem with my URPA it doesn't work. An i just replace the rear sensors with some new ones. an there is no light on the monitor or sound. is there a fuse or a relay for the URPA
    Thanks in advance.
    dmarlow's Avatar
    dmarlow is offline Cadillac Owners Fanatic
    Automobile(s): '06' Escalade
    Sep 2006
    Southern California
    58
    182
    Re: escalade 2002 URPA
    Maybe a stupid question, but is it activated?
    Not sure about the 02's but my 06 has a button on the dash to turn that function on or off.
    I had mine at the dealer shortly after purchase for some other reason and told the service adviser the backup function was not working.
    He pushed the switch to activate it and I felt pretty dumb.
    Did you check the plug connector under the rear bumper?
    Jun 2007
    7
    yes the button on the dash it activated..
    an all the sensors is connected at the rear bumper..
    trodder is offline Cadillac Owners Member
    Automobile(s): Current: 03 Escalade Prev: 01DTS, 98Deville, 89STS, 87Fleet
    Oct 2007
    Minnesota
    72
    Mine i found got unplugged when all I was getting was the red light and no sound. Plugged them back in and I was golden.
    Oct 2007
    Minnesota
    72
    In this case it looks like there is NO light so I would guess it is a fuse or a relay... or worse a bad wire somewhere.
    Jun 2007
    7
    does anyone know where the urpa controle module is located.. ?
    dchgomag is offline Cadillac Owners Member
    Automobile(s): 2001 SeVille STS
    Dec 2011
    Madison, WI
    43
    URPA
    Where are the fuse(s)/relays?
    I own a ‘01 STS. The URPA has not worked since my purchase. Single, flashing red light and no audio. I removed the bumper cover and visually inspected each unit. Wires, clips, harness, sensor's; all appear in good shape. At the salvage yard, I purchased one sensor. The left, turn/brake light lens is damaged so I figured if a sensor was damaged, more than likely it would be the one closest to that lens.
    I removed that sensor and installed the salvage yard unit hoping it was in good working order. After replacing that unit I connected the wiring harness, applied the bumper cover, started the car and dropped it into reverse. Now, I have no sensor light(s) whatsoever. I reinstalled the old sensor, applied the cover, back into reverse and still no sensor light(s).
    I have a subscription with ALLDATA. There are protocols for a systematic troubleshooting, very lengthy process. Before I begin that timely process, I want to check the fuse(s) and/or relays. No where can I find this information. Not on ALLDATA, vehicles owner manual, on line….. HELP!
    Thanks for any input. D~ Madison, WI.
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    Quote Originally Posted by dchgomag
    URPA
    You need to check all of your fuses it sounds like you have a fuse blown by the way it sounds but since you have been swapping out sensors so much you may have damaged the module.
  11. Remove Advertisements
