Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac Escalade Forums > Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
cadillac-escalade
Cadillac Forums: Rear Wheel RUBBING NOISE
Old 10-13-07, 12:25 PM
View smoey847's Photo Album
Casino Cash: $370
-2004 Cadillac Escalade
At speeds over 30ish, i am getting this super annoying rubbing noise from, what sounds like, the right rear quarters. You can only hear it if you are riding in the middle or back seats. The stock wheels have been replaced by 22" Vogue rims. Looking at them from the front of the car, they are a lot wider than the original ones. Could this be a problem? Also, when I took it in to be serviced, they said that the REAR breaks are worn 80%. Could this cause the noise? PLEASE help me. It is extremely annoying, and I feel like something is wrong. Thanks!
  #2 (permalink)
Old 10-15-07, 09:25 AM
Moderator
Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's
View hcvone's Photo Album
Casino Cash: $3535
Re: Rear Wheel RUBBING NOISE
Tough to tell without hearing the noise, you maybe hearing the rear low brake pad sensors that will rub the rotor when they get low enough. Has the noise been there since the wheels were installed?
Carl V.
**Authorized Zaino Distributor **
**Authorized Amsoil Dealer**
Web Site hcvind.com
  #3 (permalink)
Old 10-15-07, 09:34 PM
Casino Cash: $370
Well, I purchased the car with the rims already installed. I can't exactly remember if it made the noise when I got it. The brake sensors is a big possibility, as i think Firestone mentioned that when I had an inspection, but i didn't want to go replacing unneccessary parts. It's strange to me how the front brakes are worn 35%, while the rears are worn 80%, since the most pressure is on the fronts. Strange. Thank for your suggestion.
  #4 (permalink)
Old 10-16-07, 09:13 AM
Moderator
Casino Cash: $3535
Several owners reported going thru rear pads before fronts, which yes is strange.
  #5 (permalink)
Old 11-08-07, 11:30 AM
Cadillac(s): Cadillac Escalade ESV On 24's
View JNL518411's Photo Album
Casino Cash: $250
I have the ESV and my truck was at the dealership for a week before they figured out where the rubbing noise on the back of my truck was coming from. I have 24 inch wheels on it as well. They finally found it, it was my rear wheel bearing or axle bearings that were making a rubbing sound when I sped up just as you are hearing. All this after they rebuilt my front diff new u joint rebuilt the rear diff, new front hub bearings new rear brake shoes and pads and rotors. It was almost 7 K in work and they couldnt find the noise until all of that was fixed then they finally found it. Thank God For Warranties!
  #6 (permalink)
Old 11-08-07, 01:31 PM
Cadillac(s): Current: 03 Escalade Prev: 01DTS, 98Deville, 89STS, 87Fleet
View trodder's Photo Album
Casino Cash: $314
as far as rear brakes worn first it seems you are not the first owner... that said perhaps the fronts have already been replaced once?
Tags:
noise, rear, rubbing, wheel
