How do I set my garage door opener in my 2000 Escalade?
Results 1 to 5 of 5
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Discussion, How do I set my garage door opener in my 2000 Escalade? in Cadillac Escalade Forums; There is 3 buttons??...
    jayinsac is offline Cadillac Owners Member
    Mar 2004
    6
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,280
    Re: How do I set my garage door opener in my 2000 Escalade?
    Not trying to be a smart a$$ but do you have your owners manual? It's in there. I am going from memory on this, first you want to erase anything that is in there now, for that hold the 2 outside buttons on the trucks buttons for the opener for about 20 seconds until the light flashes quickly, then release, this will erase anything in memory. Next deceide what button you want to use, hold your garage door opener remote against the trucks buttons so you can still see the little red light, hold both buttons (the remote opener and your trucks button) until you see the little red light on the trucks buttons flash slowly then quickly, this can take a minute or two, when this happens release both buttons, it should be programmed. One note, some of the newer garage door openers use rolling codes for securty, if the above did not work ( i.e. the door will not work with the newly programmed truck button) then repeat the above, but after you release the buttons then you will have to push the button that will be located on your garage door opener, this is usually located on the main part of your garage opener itself.
    03whiteext's Avatar
    03whiteext is offline Cadillac Owners Member
    Jan 2004
    colorado
    44
    53
    you are correct hcvone
    invincible569 is offline Cadillac Owners Member
    Feb 2004
    87
    I followed the rules so many times and couldnt get mine to work. I have a Genie door opener and I looked on the website and it did support the Intellicode. I looked for a button/switch on my garage door opener (the main engine) and couldnt find anything. Do I need to open the case to find this button?
    Apr 2003
    13,280
    Quote Originally Posted by invincible569
    It's usually under the light defuser, that is where mine was, not sure if we have Genie but I believe they are. Look in your garage door opener instruction book
  8. Remove Advertisements
