Results 1 to 2 of 2
Thread: What is this
    slk230mb's Avatar
    slk230mb is offline Moderator
    Automobile(s): Now: 2008 STS-V, 1960 Eldorado Brougham Then: 2002 Escalade
    Feb 2004
    Bayside, NYC
    31
    5,826
    What is this
    This afternoon while I was chaning my turn signal bulbs, i discovered a wire, that looks like it should be plugged in somewhere. Look at the pics below. After thinking about it some more, could this possible be a temperature sensor or thermostat? BTW, i found this under the right headlight assembly
    ~Steve
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,299
    Re: What is this
    Passanger side correct? That is the temp sensor, there is a hole that it plugs into just under the ballast, I know this because when I replaced my amber turn signal bulbs mine was out too, I pluged it back in, the fit is not tight but it should stay in place, some times taking the headlight assy out pulls it out. You will what looks like a rough drilled hole, just push it back in and it will be fine.
  • You may not post replies
