  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac Escalade Forums > Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
cadillac-escalade
Cadillac Forums: Transfer Case
Old 04-16-07, 04:43 PM
Cadillac(s): Cadillac
View shakazulu12's Photo Album
Casino Cash: $250
Transfer Case
Does anyone know which transfer case was in what years of the EXT?
I know for 2002 it had the NVG149 in it, but I can't find anything after that.
Or, to phrase this better. Did the EXT ever go to an open differential with no viscous coupling, and if it did, what year did that happen?
  #2 (permalink)
Old 04-16-07, 04:51 PM
Playdrv4me's Avatar
Cadillac(s): Does it have wheels? Odds are I've driven it.
View Playdrv4me's Photo Album
Casino Cash: $10537
Re: Transfer Case
2002-2006 were all the same. The only years that were different were 1999-2000.
"You ough'ta go and find a brain sale... And find a cheap one, cause you ain't got no trade-in!" - Red Fox
  #3 (permalink)
Old 04-16-07, 09:02 PM
Casino Cash: $250
Re: Transfer Case
Thanks! Been looking all over for the answer to that one.
  #4 (permalink)
Old 04-16-07, 11:36 PM
Playdrv4me's Avatar
Casino Cash: $10537
Re: Transfer Case
No problem. This is one of my DISlikes about the Escalade. Due to the market that the Escalade was intended for (and thats not really even fair because the Touareg, Range Rover, and Navigator all have selectable low ranges), they decided to make the Escalade AWD only from 2002 on.
My 2004 Avalanche by comparison, had the trick transfer case setup which would allow you to select 2, 4HI, 4LO *OR* 4 ALL TIME *if* you wanted it.
Theres a few implications as a result. Number one is the fact that parts are always wearing, number 2 is the fact that you get inherently better fuel economy when your running in 2WD versus AWD mode, so its nice to be able to SELECT 2WD for dry pavement use, rather than be forced to use AWD all the time, regardless of how it applies power.
  #5 (permalink)
Old 04-17-07, 12:20 AM
Casino Cash: $250
Re: Transfer Case
I'm actually on the side that cares more for the AWD system than anything. This will get used almost exclusively on ice and snow. While 4wd is fine on snow, I much prefer AWD on ice, as the front end doesn't get pushed out in corners.
The only wheeling I do, I have always been able to drive a passenger car to, so I'm part of the group that doesnt need a true 4WD system, though I do admit, it would be way better if they made it selectable. I swear it couldn't have cost that much to add a center lock and a low range? But I also see how the market for the EXT is different than the Avalanche, which is more likely to be used in mud/sand on construction sites and as a general workhorse vehicle.
My concern on the transfer case is that the NGV149 has come in and out of the lineup with GM over the years from what i have seen printed (Yukon Denali in 01 and 02, Sierra Denali in all years, Escalade SUV only 01-02? and a few other models here and there). It differs from the other AWD systems in that it has a mechanical viscous couple that routes up to 100% of the power front to back, makes a huge difference for my needs. I'm not a fan of the ABS based traction control systems that use an open diff, if you get stuck, the wrong wheels spin every time. Was all set on the Sierra Denali until I sat in the extended cab version last weekend and it wasn't big enough, and the bed on the crew cab is too small to put drywall or plywood in it. I have rentals and flip houses here and there, so sometimes I need all the room I can get. The EXT seems to have every feature that I need, and I saw an 04 on craigslist today for 21k, which really got my attention.
Thanks a ton, this forum is a wealth of information!
  #6 (permalink)
Old 04-17-07, 12:37 AM
Playdrv4me's Avatar
Casino Cash: $10537
Re: Transfer Case
Glad to help. Be wary of ultracheap Craigslist deals though. If its 21k it should have high miles or have some issue that makes it 21. Otherwise Id say its some sort of scam.
Theres an 03 with a salvage title here in FL for 20, and I paid 22 for MY 03 with low miles, which was considered below wholesale. 21 for an 04 does not sound right.
  #7 (permalink)
Old 04-17-07, 01:35 AM
slk230mb's Avatar
Cadillac(s): 2002 Aspen White Escalade
View slk230mb's Photo Album
Casino Cash: $17221
Re: Transfer Case
I've had my transfer case replaced. $1300 warranty claim.
~Steve
  #8 (permalink)
Old 04-17-07, 03:21 AM
Playdrv4me's Avatar
Casino Cash: $10537
Re: Transfer Case
How many miles are on your rig now? When was that t-case done?
  #9 (permalink)
Old 04-17-07, 08:04 AM
Cadillac Owners Master
Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's
View hcvone's Photo Album
Casino Cash: $3045
Re: Transfer Case
Transfer case oil needs to be changed even more than the trans due to it small amount of oil it holds.
  #10 (permalink)
Old 04-17-07, 01:27 PM
slk230mb's Avatar
Casino Cash: $17221
Re: Transfer Case
89k now. 72,369 when the transfer case was replaced (August of 2005).
  #11 (permalink)
Old 04-17-07, 04:55 PM
Playdrv4me's Avatar
Casino Cash: $10537
Re: Transfer Case
Well I guess I should probably go ahead and do the Transmission, front dif, and Transfer case now then.
  #12 (permalink)
Old 01-11-10, 11:58 AM
Cadillac(s): escalade ext 2003
View auberypn's Photo Album
Casino Cash: $800
Re: Transfer Case
Does any one know if the tahoe front differential is the same as the 2003 ext.Thanks.
Tags: ,
case, transfer
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
