Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
 | Cadillac Forums: Factory IPOD hookup in Escalades.
04-09-07, 05:35 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Factory IPOD hookup in Escalades. I tried this the other night and it worked so I thought I would mention it to all of you in case you didn't know. You can use a 1/8 to RCA connector and plug it into your headphone jack and then plug it into the rear entertainment console in the AUX plugs and listen to your ipod by selecting AUX on the radio. It's not the best setup since you can adjust the volume off of the actual IPOD. The sound quality is night and day better than a FM modulator though.
Nick |
04-10-07, 08:48 AM
| | Cadillac Owners Master Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: Factory IPOD hookup in Escalades. I did this for a while and then switched to the Neucleus, it keeps the Ipod charged, and I download everything at 320, switching back and forth you could not tell the difference, of course if you are using 120-180 speed to download you will hear the difference, it's night and day |
04-10-07, 02:13 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Factory IPOD hookup in Escalades. Quote:
Originally Posted by hcvone I did this for a while and then switched to the Neucleus, it keeps the Ipod charged, and I download everything at 320, switching back and forth you could not tell the difference, of course if you are using 120-180 speed to download you will hear the difference, it's night and day | What is the Neucleus? |
04-10-07, 02:49 PM
| | Cadillac Owners Master Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: Factory IPOD hookup in Escalades. |
04-10-07, 03:39 PM
|  | Cadillac Owners Member Cadillac(s): Cadillac Escalade | | Join Date: Mar 2007 Location: Denver, CO | | | Re: Factory IPOD hookup in Escalades. According to the application guide its only good on 03 and up!? I have an 02, so does that mean I am SOL?? |
04-10-07, 04:55 PM
| | Cadillac Owners Master Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: Factory IPOD hookup in Escalades. Check with GM Geek (GMG) he is around this Forum every few days, he would know what will work.  |
04-10-07, 11:23 PM
| | Cadillac Owners Fanatic Cadillac(s): 2003 Cadillac Escalade ESV | | | | | Re: Factory IPOD hookup in Escalades. Quote:
Originally Posted by SteveSkal According to the application guide its only good on 03 and up!? I have an 02, so does that mean I am SOL?? | It will not work in a 2002, I am 100% sure the connector is a 9pin instead of a 12pin and I believe the radio uses a different protocal. |
04-11-07, 07:57 AM
| | Cadillac Owners Master Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: Factory IPOD hookup in Escalades. Didn't GMG have a setup for the 02's? Just not sure.  |
04-11-07, 09:25 PM
| | Cadillac Owners Member Cadillac(s): 07 Escalade EXT | | | | | Re: Factory IPOD hookup in Escalades. Hey guys, going back to NBOMAR's original post, where is this "aux" input on the rear console? The console in my EXT only has what appear to be 2 outputs for headsets (I could be wrong), nothing labels "aux" or "input". Sorry if this is obvious to everyone but me  |
04-12-07, 07:42 AM
| | Cadillac Owners Master Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: Factory IPOD hookup in Escalades. You only have that if you have rear seat ent. option | | Cadillac Discussion Tools | | |
Censor is ON | | | |
