  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac Escalade Forums > Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
Cadillac Escalade, EXT and ESV Forum - 1999 - 2006 Forum for discussions regarding the First and Second Generation Escalade 2WD, AWD, EXT and ESV.
cadillac-escalade
Cadillac Forums: What size tires won't rub at all
Old 04-01-07, 10:03 PM
SteveSkal's Avatar
Cadillac(s): Cadillac Escalade
View SteveSkal's Photo Album
Casino Cash: $1160
Yes, its the newby again I have to really start thinking about what size rims and tires I want to put on my new 02 lade, now its seems 22 inch rims are the most popular size and from the wheel tire packages out there 305/45/22 seems to be the most popular size tires, so from the guys who have this size on their Escalade's can you verify that the tires won't rub AT ALL, and I stress that because I had 20 inch rims on my 99 Jeep Grand that I just got rid of and when the wheel was cut all the way over it would rub the fenderwell and make a God awful noise and I don't want to make the same mistakes with my new ride. I hated being in parking lots and have people look and say "cool looking Jeep" then I'm trying to pull in a spot and the noises coming from my car are audible in the next county! LOL
  #2 (permalink)
Old 04-02-07, 01:24 AM
Cadillac(s): 07' Escalade Quicksilver
View Killertraylor's Photo Album
Casino Cash: $250
Re: What size tires won't rub at all
265/75/18's don't rub AT ALL - I swear!
  #3 (permalink)
Old 04-02-07, 08:47 AM
8ball's Avatar
Cadillac(s): '05 Escalade EXT
View 8ball's Photo Album
Casino Cash: $358
Stock doesn't rub at all I used to have this set up, 305/45/22 and they did rub mostly when backing up.
  #4 (permalink)
Old 04-02-07, 04:53 PM
SteveSkal's Avatar
Casino Cash: $1160
Hmmm, so would you recommend 20 inch wheels, or 22's but with a slightly smaller tire? I want the biggest I can get with ZERO rubbing
  #5 (permalink)
Old 04-03-07, 01:06 PM
Cadillac Owners Enthusiast
Cadillac(s): 2006 Escalade
View jordan00escalade's Photo Album
Casino Cash: $1590
285/45/22 I have a 2000 Escalade, which is a little different from yours but they didn't rub.
  #6 (permalink)
Old 04-03-07, 06:08 PM
Cadillac(s): Escalade
View erf2u's Photo Album
Casino Cash: $410
I also have an 02 with 22's. The original tires that were on was the 305/45/22. It had rubbing issues in the front tires when turning at the most extreme left or right, and more often when turning in reverse.
This caused the inner fender walls to wear down all they way through where the tire rubbed.
Fortunately, the tires were in need of replacement, so I went with 305/40/22. Now I have no issues or problems whatsoever.
  #7 (permalink)
Old 04-04-07, 02:13 AM
SteveSkal's Avatar
Casino Cash: $1160
Thanks for the info. Do you still have good ride quality with the 305/40's? Also in looking at rims I've seen 2 I really like so far and in reading the specs, one has an offset of 12mm and the other 25mm, now what does this mean exactly and how will that now possibly affect tire rubbing? Thanks
  #8 (permalink)
Old 04-04-07, 04:43 PM
Casino Cash: $410
Yes, the ride quality is still very nice and smooth.
As for the offset, it will make a big difference to the fitment on your lade. The offset is the distance from the face of wheel, (where it mounts to the hub of the car) to the inner side of the rim. A positive offset means that the tire profile is positioned more into the car. A smaller offset or negative offset will position the tire outwards (deep dish is what they use to call them).
With a smaller offset, you will risk rubbing in both front and back depending on the amount. For the front, you may expect to rub when turning. For the back, you may rub along the top of the fender well if you are lowered or when you hit a big bump.
Most smaller wheel shops will let you try on both sizes to make sure that it fits correctly, and to keep your business. I noticed some of the bigger shops do not test fit them, and they give you a story of why their recommendations are your only option.
Good luck!
  #9 (permalink)
Old 04-05-07, 12:50 AM
View LADE in the SHADE's Photo Album
Casino Cash: $250
Steve, If I can correct erf for accuracy, greater negative offset moves the rim outward more. negative offset means that the mounting surface is in from the center. As the number gets bigger, say from 12 to 20mm, the wheel moves out as long as wheel width didnt change. I have 22x10 with 20mm offset and 305/45/22s and they rub. 305/40/22s wont rub. i like the ride w/ 45 series better (and better fender filling). I resolved 95% of the rub with a little cut to the lower front edge of the outer fender and some zip ties to the inner fender. the remaining occasional rub is no trouble to me and I am pretty particular w/ perfection. On a 10" wheel I would go w/ 20mm. Less and it rubs the inside more, greater and it rubs the outside.
  #10 (permalink)
Old 04-05-07, 01:38 PM
Casino Cash: $410
Originally Posted by LADE in the SHADE View Post
..... negative offset means that the mounting surface is in from the center. As the number gets bigger, say from 12 to 20mm, the wheel moves out as long as wheel width didnt change. I have 22x10 with 20mm offset and 305/45/22s and they rub....
Just a clarification....from Steve's message, I interpreted his choices were between two Positive offsets. In which, the smaller the offset, the further out the wheel moves, or as I also mentioned, a negative offset will also do the same, when comparing to a positive offset.
Your comment is true if he were comparing only negative offsets.
Does your wheels have a positive 20mm offset or a negative one?
Tags:
rub, size, tires
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
