I've driven an ELR, and I'm very impressed...but not sold
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Like Tree2Likes
Cadillac ELR Forum Discussion, I've driven an ELR, and I'm very impressed...but not sold in Current Cadillac Vehicle Discussion; I had the pleasure of test driving an ELR today. On a whim last Sunday, I checked Cadillac's inventory in ...
    Blastphemy is offline Cadillac Owners Enthusiast
    Automobile(s): 2018 CT6 plug-in
    May 2012
    Montana
    555
    I had the pleasure of test driving an ELR today. On a whim last Sunday, I checked Cadillac's inventory in my area and discovered that a nearby dealership had received two. When I arrived at the dealership, I was told the first one had been sold, but the second was available for a test drive. The salesperson got permission from his manager to let me drive a few exits on the highway, so I was able to reasonably put it through its paces.
    Some quick answers to questions I've seen posted here and on other forums:
    1) The volume of the range extender engine is about half as loud as the Volt's. The mainstream reviewers who complained about the volume of the 1.4L DOHC I-4 engine were exaggerating and inaccurate. The harsh treble and overtones have been successfully muted and those frequencies do not intrude into the cabin. Yes, you can still hear the engine at higher RPMs, but the noise is absolutely not as loud as the Volt's.
    2) The rear seats do fold forward to allow more room in the trunk, but the center section between the seats does not. So you're always going to have an obstruction in the middle when the seats are folded down.
    3) The stereo system power button works exactly as it should, turning off the stereo but not the entire C.U.E. infotainment system.
    4) The reverse camera is better than the Volt's, and includes the directional guide lines that are missing in 2013/14 Volts. However, I did not have the opportunity to test the backup camera at night or in a dark garage to see if it automatically sets the brightness and contrast properly regardless of the nighttime dimness setting of the instrument panels. It's still not as good as the camera in my wife's Rav4 EV, but it's definitely an improvement over the Volt's.
    5) The navigation system does not zoom in to a "building scale" mode like systems in many other ~$80k cars.
    6) The ELR does not offer the option of cooled front seats like many other ~$80k cars.
    7) I did not see a CD player in the car as part of the C.U.E. system, but it occurred to me later that it might be in the glove box like in the CTS. Label this question "unanswered" for now!
    8) I'm 5'7" and didn't fit in the backseat without slouching uncomfortably or sliding my butt forward. However, it was still a little more spacious than I expected. My wife, who is 5'4", fit comfortably. The problem is not a lack of legroom, but rather there's a lack of headroom due to the precipitously sloping back window.
    9) The ELR has powered climate-controlled cup holders and a powered glove box opener, but no power folding mirrors. Go figure...
    10) The regen paddles behind the steering wheel (which feel more like the large inset buttons you'd find below the trackpad on a laptop computer) are either on or off; there are no gradients of regen available. The left and right regen paddles perform the same function, as best I could tell. The paddles move around with the steering wheel, so holding them while turning is not easy (although by the time you're into a 90-degree turn, you usually won't need additional deceleration). To me, it felt like the paddles slowed the car a bit more than throwing the shifter into "L" mode.
    I'll start my review here so that it begins on a positive note: The regen paddles are an epiphany. The thrill of not having to reach over and shift into 'L' every time you want to slow down is more satisfying than I thought it would be. The placement on the steering wheel is ergonomic, the regen engages instantly when pressed, and it's very smooth. If you're a Volt owner like me who typically drives in 'D' but shifts to 'L' every time you want to slow down, this feature will ruin you for the Volt.
    But let's go back to the beginning... As I walked through the dealer's lot, I saw one CTS after another, wondering which one would turn out to actually be the ELR. But when I turned a corner and saw the ELR sitting by itself, it was obvious that it could never be confused with a CTS. It was jaw-droppingly gorgeous and will take your breath away. As others have said, photographs really don't do it justice. This was the Converj concept car I saw at the 2009 auto show, at least on the outside.
    Inside, the car is comfortable, has spacious front seats with reasonable headroom (if you lower the seat), and all controls are placed within easy reach of the driver. For the most part, button controls and the C.U.E. system act as expected and are intuitive. The steering wheel controls, though, may take a bit of practice to master because it isn't obvious what certain things control, nor all the possible ways one can select a button. For example, the main selector on the right side of the steering wheel allows for left, right, up, down, and enter, although the tactile feel of the button only clearly conveys the ability to select left and right, and that selector doesn't seem to have the ability to control selections on the center nav screen (i.e., it's only for the instrument panel behind the steering wheel).
    Entering a destination in the C.U.E. system navigation was very fast. Letters appear as quickly as you can type them, and you enter the address all at once instead of by city, then street, then house number. You can also use the voice controls to enter an address, which worked perfectly the first time I tried it. I even tried to throw it off by speaking "Navigation Controls" then "Cadillac" as the the point of interest, but it immediately found the dealership and allowed me to select it from the center screen from among additional choices.
    My two big navigation system disappointments are that it can't zoom in to "Building Scale," and that the sound of the navigation voice is terrible. IMHO, an ~$80k car should not have such a cheap sounding voice. My $62k 2011 Infiniti M56, and all 2012+ Infinitis, have a natural system voice that is pleasant, articulate, and was nearly indistinguishable from a real person. But the ~$80k ELR's nav voice sounds more like the robotic computer from a second-generation 2004 navigation system. It was worse than the Volt's.
    Regarding battery information, I couldn't find a physical "leaf" button anywhere on the instrument panel to bring up battery information. The only way I found to get to that screen was to press the virtual leaf button on the C.U.E. screen, and it wasn't on every screen.
    When I tried to pair my iPhone 5 to the C.U.E. system, it worked like a charm. Took fewer than 20 seconds for the whole process.
    Once my phone was connected, I played some lossless hi-fidelity tracks from iTunes. Speaking as a professional musician, I didn't think the sound system was remarkably better than the Volt's. It sure as heck didn't perform to the level of the Mark Levinson audio system found in the ~$80k Lexus LS460.
    The Lane Departure Warning system was as annoying in the ELR as it was in my Infiniti. Trying to convey everything by buzzing the seat under your thigh is not very clear or efficient. I was getting buzzing for lane departure, for Cross Traffic Alert, for obstacles when parking in reverse, etc.... it was useless! You couldn't differentiate what it was trying to tell you, nor which system was activating it. Give me localized beeps and targeted light warnings any day!
    I didn't have the opportunity to test the Adaptive Cruise Control system, although my test car did have that option installed.
    As reported by some mainstream reviewers, the visibility in the ELR is worse than in the Volt, but I wouldn't consider it awful. Sure, it would be great if the rear window had a bit more size and the 'A' pillars were less intrusive to your line of sight, but I've driven cars with worse visibility.
    Some high-end cars have a feature that automatically moves the driver's seat back when the car is turned off (to allow for a more comfortable exit). The ELR does not have this feature. The ELR also doesn't have a head's-up display, nor did I see evidence of a Blind Spot Warning system (unless that was also the damned buzzing alert under my leg).
    OK, so how did it drive? If you're still with me at this point, I assume you've been wading through everything above to find out my impressions about that. Well, it felt like I was driving an expensive Volt. In normal driving, the ELR was exquisite: quiet, comfortable, smooth, and refined. However, I still felt bumps in the road, although perhaps a bit more muted than in my Volt.
    The ELR did not feel any faster than the Volt, even though I had Hold mode engaged. Apparently, the 7.8 seconds from 0-60 is only available when you're in range extending mode, not just in Hold mode or Mountain mode. If the faster acceleration actually was available in Hold mode, I didn't feel the difference. The gas engine did eventually rev up when I floored it, but not right from a full stop. The gas engine in Hold mode appeared to engage exactly the same as it does in a 2013/14 Volt in Hold mode.
    After trying Hold mode for a little while, I changed to Sport mode to see if that made any difference. Well, it did - the ELR was a lot more responsive earlier in the accelerator pedal travel. But it felt exactly like my Volt. And since there isn't any discernible way to engage both Hold mode and Sport mode at the same time, I'm at a loss as to what the heck Cadillac was thinking when it decided to give the car some more oomph with the engine running, but then didn't give the driver a way to use it while the battery still has a charge.
    And that's the crux of the problem I still have with this car: Unlike the Volt, the ELR has a HiPer strut front suspension to help lessen the effects of torque steer, a semi-independent rear suspension with a Watts Z-link for better stability in corners, and Continuous Damping Control that adjusts shock dampening every two seconds according to the current driving situation. But because the ELR didn't improve its overall performance, it's all wasted! It feels like I'm driving a Buick (which is not necessarily a bad thing, as I find Buicks very comfortable) rather than a Cadillac because there's nothing in the acceleration or front-wheel drive that allows me to take advantage of the upgraded struts, suspension, and damping!
    I pushed the ELR as hard as I could, and while it felt more refined, the driving experience was not so markedly better than my Volt's to make it worth twice as much money to me. Because of this, I've decided that I'm not getting the ELR without a very aggressive lease program. Why? Let me pose this question to you: If Chevrolet told you that they made the Volt faster, but you couldn't take advantage of that extra speed until the battery was depleted, what would you say?
    The more I think about Cadillac's decision to engineer the ELR to go 0-60 in 8.8 seconds in EV mode, and then...37 miles later when the battery is depleted...go 0-60 in 7.8 seconds, I just can't bring myself to support that decision with my money. What the ELR needs, IMHO, is a Sport+ mode that engages the engine before the battery is depleted so that the ELR can get 0-60 in 7.8 seconds any time the drivers wants. Just using Hold mode didn't seem to accomplish this in my testing, and - anyway - that's a completely counterintuitive decision that Hold mode (or extended range mode) would be sportier than Sport mode! Duh.
    I also don't like that Cadillac does not allow you to buy the Adaptive Cruise Control package without also buying the $1,695 Luxury package; and that I can't get the Kona Brown seats without paying for the $2,450 20-way seat controls; and that I can't get the "free" wheels with Midnight Silver premium painted accents without also buying the Luxury package.
    The ELR looks great, is quiet, comfortable, and has reasonably good tech, but it is not worth Cadillac's price, IMHO. I can't imagine Cadillac's eventual lease rates will change my mind (although I won't deny that $600-700/mo with no money down would tempt me).
    The good news is that - in lieu of an ELR - I'd be replacing my 2012 Volt with a fully-loaded 2014 Volt come June, so GM would still gets a sale, and I'd still be happy. Not sure what I'd do with the $40,000 I'd save...
    All that having been said, I can totally understand if others buy or lease this car and consider it worth the price. Some things that I care about won't even be on other people's radar, and others will just be mesmerized by the incredible look and presence of the ELR to even care about performance or whether the mirrors fold in automatically. IMHO, the ELR is a wonderful car that has some room for improvement, but Cadillac will have a lot of customers who think it's perfect just the way it is.
    DG2's Avatar
    DG2
    DG2 is offline Cadillac Owners Connoisseur
    Jul 2004
    1,703
    Thanks for the very in depth overview. I just picked up the Automobile magazine review of the ELR and must concur with you on the jaw dropping looks. The article explains GMs image goal here. This car fir people with the bucks is a must have. I do think it looks amazing inside and out and if it's performance matxhs the Volts that's ok cause if your rich enough may as well just get this beauty
    May 2012
    Montana
    555
    Re: I've driven an ELR, and I'm very impressed...but not sold
    Quote Originally Posted by DG2 View Post
    if it's performance matches the Volts that's ok cause if your rich enough may as well just get this beauty
    Problem is, rich people tend to want their cars to be better than other cars. I sure wouldn't want to pay double the price and get the same propulsion system.
    DG2's Avatar
    DG2
    Jul 2004
    1,703
    Quote Originally Posted by Blastphemy
    I hear you and I have been very critical of the price of this ELR. However let's be honest the powertrain in the new CTS & XTS & SRX & ATS is exactly the sane as those found in Chevy Impala, Chevy Traverse, Buick Enclave , Buick Lacrosse. People spending $75k up for an escalade are also sharing that engine/powertrain with Chevy models too. So plenty of rich people out there that are not bothered and don't care about power train shared. I hear what you're saying but it seems like most people don't give hoot
    Oh. By the way while I'm not rich yet I did buy a $75,000 Escalade and live the power train. Even though I see drivers of Tahoes costing $10-15 k less. I'm not bothered.
    May 2012
    Montana
    555
    What?!? The Escalade has a 6.2L Vortec® V8 Variable Valve Timing (VVT) engine with 403 hp @ 5700 rpm, 417 lb-ft of torque @ 4300 rpm, and a Hydra-Matic 6L80 heavy-duty 6-speed automatic transmission. The Tahoe has a 5.3L Vortec V8 SFI FlexFuel engine with 320 hp @ 5400 rpm, 335 hp @ 4000 rpm, and 4-speed 4L80E automatic transmission.
    Those are not "shared" engines; the Escalade is noticeably more powerful than the Tahoe. The ELR is exactly as powerful as a Volt unless you deplete the battery (which makes absolutely no sense).
    DG2's Avatar
    DG2
    Jul 2004
    1,703
    What?!? The Escalade has a 6.2L Vortec® V8 Variable Valve Timing (VVT) engine with 403 hp @ 5700 rpm, 417 lb-ft of torque @ 4300 rpm, and a Hydra-Matic 6L80 heavy-duty 6-speed automatic transmission. The Tahoe has a 5.3L Vortec V8 SFI FlexFuel engine with 320 hp @ 5400 rpm, 335 hp @ 4000 rpm, and 4-speed 4L80E automatic transmission. Those are not "shared" engines; the Escalade is noticeably more powerful than the Tahoe. The ELR is exactly as powerful as a Volt unless you deplete the battery (which makes absolutely no sense).
    The Tahoe and Denille both have Variable Valve Timing. Have to double check but I believe the GMC Denali offers Votec 6.0 and Tahie has option. 4 speed ?? I'll have to double that too. But , that's only one model, all the Caddy Sedans I listed plus SRX share there 6 and 4 cylinder engines with less expensive GM brands. That said the report you gave about your experience today says it perfectly. The ELR is jaw dropping gorgeous , dramatically a stand out even next to the hot new CTS. Interior light years ahead of Volt , much quiter ride etc. So why shocked if sane performance as volt ? Isn't it the same when someone buys the 6 vvt in CTS vs Lacrosse ? I think you made a great selling point for the ELR and that's not a bad thing.
    Ok. Not sure what year your 4 speed tranny comment was referring to but I just confirmed thecTahoe has a 6 speed tranny not 4!!
    May 2012
    Montana
    555
    I think you're seeing what you want to see in my review. It is by no means a plug for the car; quite the opposite. The ELR is missing standard features one expects in cars that cost $10k-$25k less, and the luxury features it does have are not all implemented well. If you're willing to pay twice as much for it because it's prettier than a Volt, then go ahead and spend your money - that's your right. But those of us who can spot a bad deal from a mile away won't touch the ELR unless lease rates are artificially low. BTW, perhaps you might want to proofread your responses before posting? It's hard to wade through the copious typos, friend. Have some self respect!
    DG2's Avatar
    DG2
    Jul 2004
    1,703
    I wouldn't worry so much about my typos versus getting your facts straight about a car. Saying that a Chevy Tahoe has a four-speed transmission and does not have variable valve timing ? come on get real you should be on another forum dude !
    May 2012
    Montana
    555
    Kind of like your saying the the Escalade's transmission and acceleration is the same as a Denali (or Denille, as you spell it) or Tahoe. Right. Opinions aren't facts, unfortunately for you.
    DG2's Avatar
    DG2
    Jul 2004
    1,703
    I know how to spell ******* especially when I'm responding to one. You don't belong on this forum especially when you have your facts 100% wrong . I suggest you go drive your local Cadillac salesman nuts and test drive the ELR again maybe they'll give you a free doughnut.
    May 2012
    Montana
    555
    Just heard from my dealer that the first ELR lease program is $975/mo + sales tax for 36 months @ 10k miles annually, with a 51% residual. That's the final nail in the coffin for me, unfortunately. Waste of money, IMHO.
    I like how mistyping '4' instead of '6' in one place means all my facts are wrong. That's very funny, DG2. You're the one who incorrectly claimed the Escalade had the same engine as the Tahoe, not me.
    dengland is offline Cadillac Owners Member
    Automobile(s): 2014 ELR
    Jul 2006
    FL
    65
    Quote Originally Posted by Blastphemy View Post
    Ouch. Thanks for the insights.
    pissedoffwookiee's Avatar
    pissedoffwookiee is offline Cadillac Owners Connoisseur
    Automobile(s): '16 CTS V-Sport Black/'16 CTS Luxury w/V-Sport Pkg White
    Mar 2013
    Carlsbad, CA
    3,803
    There is a better lease imminent about 300 less than quoted above...... I had a thought about pricing I'm getting used to it, and what helped was this notion...... If you take voltec out of the volt you have a cruze and pricing is about 20k reduced to a sub 20k car.... If you take voltec out of ELR you basically have a premium CTS coupe which goes for 55k add 20k for voltec and you're at the ELR price.... This kinda makes pricing make a little more sense.... Still don't know how people will bite but doesn't seem as expensive especially when you compare to Tesla and BMW i-cars are going to be expensive
  16. #14
    May 2012
    Montana
    555
    Quote Originally Posted by pissedoffwookiee View Post
    Do you mean $300 less per month? If so, I can definitely be happy with a $675/mo + tax lease on an ELR. Absolutely.
  17. #15
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    679
    Blast stick to you're volt, we don't need you're sparks. Have you ever owned a CADILLAC?
  18. Remove Advertisements
