For Sale 1995 Eldorado bagged with accuair suspension, Motivated Seller!!!
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 1 of 1
Cadillac Eldorado Classified Ads Discussion, 1995 Eldorado bagged with accuair suspension, Motivated Seller!!! in Cadillac Classifieds Marketplace; I need to change vehicles due to needing more doors and/or 4wd/awd so I am selling my ride...may be open ...
    atvsmurf is offline Cadillac Owners Member
    Automobile(s): 95 Eldorado
    Jan 2012
    44
    3
    I need to change vehicles due to needing more doors and/or 4wd/awd so I am selling my ride...may be open to trades...jmurphy@students.acpharm.org, just mention seeing my post on here please. I would like to get around $6k out of it, but my reserve is less on the auction and will listen to any offer!!!
    This is my red 95' eldorado with under 48k miles. The car is in great condition and runs great. I bagged it in the spring and am selling it after 7 months and 7k miles on the suspension... I am running a set of 18" chrome rims that still look nice but do have some pitting up close...and the tires are new...
    Here is a link of it working.. http://us.yhs4.search.yahoo.com/r/_y...fv=siAHpRj7dwI .and it is only set to run at 150 psi currently...I just set it there to keep wear down on the compressor...I can be adjusted up to 175 or 200...I think I mistyped 175 on my video description on auction listing one...so disregard that please...
    I built it around the VU4 valve body and used 3/8" dot line and all metal Alkon swivel fittings at each of the bags, controlling the valve is accuair's e-level running the i-level wifi. It has a single compressor, SMC water trap and 5 gallon tank plumbed with, a pressure safety blow off valve, drain petcock, pressure switch and a schraeder valve and also a quick coupling for the air hose that goes with it...along with the tire fill valve and other fittings.
    I wired the setup using a stereo amp install kit and loomed the cable and hoses as I ran them thru the interior to keep them out of the weather and harms way. In the trunk, I used 2 distribution blocks; one for power to the components and one for the grounds... I figured if I wanted to install amps, that would already be out of the way... The trunk is not complete as I did not have time to finish it and still havent gotten around to it.. but I made sure to leave enough extra tubing and wires that the components could be relocated anywhere in the trunk, or even under the rear bumper cover... I have placed it on ebay and my reserve is well below what I have put into the car and parts...I am located in Beckley WV currently but travel to Eastern KY quite often. I can meet someone with the car or drop it off at a shipping company...the link to the auction ends on november 25 after 7:00 pm and is http://www.ebay.com/itm/151169915137...84.m1555.l2649
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
