Disabling Seat Belt Chime (07 DTS)
Results 1 to 9 of 9
Cadillac DTS Forum - 2006 through 2012 Discussion, Disabling Seat Belt Chime (07 DTS) in Past Cadillac Vehicle Discussion; Does anyone know how to disable the seat belt warning chime? Please don't give me any lectures and it is ...
    traffic_pe is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2006
    Does anyone know how to disable the seat belt warning chime? Please don't give me any lectures and it is not illegal, just the proceedure that does not involve cutting or butcheriing. This is a sophisticated car. I recently found the proceedure for the full size Fords.
    malcolm's Avatar
    malcolm is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 CTS
    Mar 2005
    Northern NJ
    1,192
    Re: Disabling Seat Belt Chime (07 DTS)
    go to a junk yard and cut the clip off a GM seatbelt and plug it into yours. or you could make one. I bet you could cut one out of cardboard or maybe a piece of plexi glass and slip it into the seat belt. beats fooling around with the electronics
    Oct 2006
    Thanks, I thought of that. My 2005 ford Crown Vic had a long and complicated set of instructions where you need to turn on the ignition, and plug and unplug the seatbelt 10 times within two minutes and the computer would disable the warning. So I'm sure the Cadillac has the same feature, but it is likely a trade secrete, as the manuf does not want the general public to know. And I agree, the general public are IDIOTS.
  5. #4
    GTXgp is offline Cadillac Owners Member
    Automobile(s): '08 Escalade AWD
    Jul 2005
    Plano (Dallas), TX
    17
    Sorry for such a late reply... hopefully you have already figured out a solution. But, if not I have a very simple one for you. Normally there is a procedure for going into the settings to disable. However, the procedure is not in the owner's manual and I have not been notified of a Helms manual available for the car yet. Luckily, I have an easier approach that worked like a charm for me
    Simply look under the seat and find the seatbelt sensor wire (tucked neatly under the seat near the base of the seatbelt latch) and simply disconnect the wire.
    GM is sorta backwards from the way you would expect the car to react. You would think if the sensor is disconnected it would chime all the time but it is actually the opposite. Disconnecting it will eliminate the chime and you can quickly and easily plug it back in whenever you want.
    Let me know how that goes and if you have any other questions...
    Adam
    '06 Lucerne CXS
  6. #5
    mack1a's Avatar
    mack1a is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS Performance Level 2006 CTS
    468
    What is a Helms manual. Is that something full of goodies such as eliminating the mommie scold you always get on the Nav system every time you start the car and possibly allowing the driver to set a destination while underway?
  7. #6
    Jul 2005
    Plano (Dallas), TX
    17
    Helms manuals are basically 100% full function service manuals (not those crappy chilton ones you get at Autozone). And, since I went to their site to get the link it looks like they DO now have them available for both the 06 DTS & Lucerne for that matter I requested an email update from them when it was available... I guess they forgot
    http://www.helminc.com/helm/Result.a...C795KCXS4GESCC
    That link should work. If not, simply go to www.helminc.com and click on vehicle owner then choose your make, etc
    On my link, the service manual you would want is the second link "2006 Cadillac DTS (KS-Platform) Service Manual Set" ...I see they also have one specific for the nav system that might help you disable that annoying feature
    I'm ordering one right now, and I highly suggest it if you plan to do any tinkering.
    Adam
    '06 Lucerne CXS
  8. #7
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    I think if you buckle the seat belt the chime will stay off and the light in the IPC will go out.
    That doesn't involve cutting anything.
  9. #8
    Jul 2005
    Plano (Dallas), TX
    17
    Quote Originally Posted by ewill3rd View Post
    I think the question here is... what if (for whatever reason) you don't want to use your seatbelt).
    My method is simplying unplugging... no cutting required and can be disable/re-enabled in about 30sec.
    I am curious if the service manual has some way to disable it in the computer like most other cars have.
    Adam
  10. #9
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    No, the service manual does not have information on disabling this system.
  11. Remove Advertisements
