tire pressure monitors
Results 1 to 4 of 4
Cadillac DTS Forum - 2006 through 2012 Discussion, tire pressure monitors in Past Cadillac Vehicle Discussion; I am new to this web site and posed this question in the wrong category so I am trying to ...
    happysam is offline Cadillac Owners Member
    Automobile(s): Cadillac 2006 DTS
    Oct 2006
    Pickering Ontario Canada
    3
    I am new to this web site and posed this question in the wrong category so I am trying to list the question again, hopefully in the right section this time.
    I have a 2006 DTS performance model with 18" wheels. I live in Canada and would like to put winter tires on to save the original rims. I have a chance to get rims off a 2005 STS 18". Does anyone know if the tire pressure monitors from the STS will work on my new DTS? thanks Cliff
    Murphyg's Avatar
    Murphyg is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 STS
    Oct 2003
    Ontario
    1,575
    Re: tire pressure monitors
    Im going to take a stab in the dark here seein as Im not familiar with how the tire pressure moniters work, or how they are connected etc.
    I would assume they are the same connections.
    Other than that the biggest concern would be as to what the pressure is set at for the sensor.
    If its the same pressure needed for the tires you want to put on it should be ok.
    Would also assume you should be able to adjust it if need be.
    Nothing in the owners manulal ?
    Sorry im just speculating.
    Jumped into this section cause Ive been eyeing the 06 DTS for a while now.
    Nice lookin ride.
    Murphyg's Avatar
    Oct 2003
    Ontario
    1,575
    Heres something I found.
    Its talkin 04 but shouldnt be that far off. Mentions about relearning the TPSM if that helps
    http://www.cadillacforums.com/forums...ssure+monitors
    Heres the rest of what I found in my search:
    http://www.cadillacforums.com/forums...earchid=216875
    Cheers
    fmoeller Guest
    Quote Originally Posted by happysam View Post
    Go to the dealer and check the part numbers for the sensors. If they are the same then you should be OK. Sensors work on radio waves by sending a signal to the on-board computer.
  7. Remove Advertisements
