Quick brake pad question.
Results 1 to 10 of 10
Cadillac DTS Forum - 2006 through 2012 Discussion, Quick brake pad question. in Past Cadillac Vehicle Discussion; A while back, I upgraded the front brakes on my Seville. The calipers are the same dual piston ones that ...
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    A while back, I upgraded the front brakes on my Seville. The calipers are the same dual piston ones that the DTS uses. I used EBC RedStuff pads and their Ultimax slotted rotors, which I also had before the upgrade. The pads that fit the stock calipers had the channel in them for the pad wear indicators, the new pads for the dual piston calipers do not. Does the DTS just not have that feature, or does EBC just not cut the groove.
    It really doesn't bother me, and I'm enjoying the upgrade, but I was just curious.
    Sep 2010
    East Boston MA.
    29
    26,323
    Anybody?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,127
    Re: Quick brake pad question.
    Don't know about the DTS Redstuff pads - but curiously, when I did the change to EBC on the STS, the rear pads were not cut for sensors. Doesn't matter to me - I check visually every couple of months. I just wire-tied the rear sensor/harnesses out of the way of any suspension moving parts.
    Stepside is offline Cadillac Owners Enthusiast
    Automobile(s): '06 DTS performance; CowboyCadillac='12 SVT Raptor
    Oct 2009
    NW Jerzey-in the sticks
    67
    631
    So, it does not have the groove and what about the metal 'wear indicator' tangs that sound off??
    Point of Interest:
    Once you have replaced the pads & rotors and topped off or changed the fluid--> (recommended)
    There should be no more 'topping off' of fluid.
    The reason is - as the pads wear, the fluid will get lower in the reservoir until the indicator light comes On.
    It is designed as such to indicate that the pads & rotors need to be checked and/or replaced at that point in time.
    This applies to most all modern cars.
    tjwhite721's Avatar
    tjwhite721 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac DTS, 1999 Cadillac Seville
    Jul 2008
    Bloomsburg,PA
    315
    I just put on Wagner Rotors and Wagner Thermo quiet ceramic brake pads. I noticed a big difference in stopping power.
    Anybody use Wagner products for brakes and rotors?
    Or the EBC's that much better?
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by Submariner409
    All of my EBC pads were cut for the sensors. EBC had just started doing it for the rear pad part number before I ordered.
    Quote Originally Posted by tjwhite721
    The EBC RedStuff pads are a street performance pad, and are excellent. Wagner replacements are a stock replacement.
    So the question remains... Does the DTS have an electronic brake wear indication system?
    ltdltc's Avatar
    ltdltc is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS4 Performance Sport Wagon
    Jun 2003
    MA
    35
    496
    [/COLOR]So the question remains... Does the DTS have an electronic brake wear indication system?
    Nope. Only the mechanical wear sensor.
    Sep 2010
    East Boston MA.
    29
    26,323
    Thank you.
    Staticxd00d's Avatar
    Staticxd00d is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Apr 2014
    VA
    48
    12
    I upgraded my fronts to the Powerstop Z26 Extreme pads and rotors, and they're awesome. Car stops WAAAAYYYY better than it did.
    tjwhite721's Avatar
    Jul 2008
    Bloomsburg,PA
    315
    Why not Brembo's?
  13. Remove Advertisements
