Motor mount going bad?
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By ltdltc
  • 1 Post By ltdltc
Cadillac DTS Forum - 2006 through 2012 Discussion, Motor mount going bad? in Past Cadillac Vehicle Discussion; I'm not too engine savvy, but I have what appears to be an engine mount or engine vibration dampener going ...
    beauimpala is offline Cadillac Owners Member
    Automobile(s): 2006 DTS 1990 Brougham
    Sep 2013
    SW Washington
    43
    I'm not too engine savvy, but I have what appears to be an engine mount or engine vibration dampener going bad? You can see in the picture it is all cracked and has actually separated from the nut completely cracking all the way through from top to bottom. Is this easy to change? Is it as simple as taking off the nut on the top and replacing with a new one? Any advice would be greatly appreciated.
    ltdltc's Avatar
    ltdltc is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS4 Performance Sport Wagon
    Jun 2003
    MA
    35
    490
    Re: Motor mount going bad?
    You need to unbolt the coolant expansion tank. Once you unmount the expansion tank you can unbolt that torque strut.
    Mine was cracked but still seemed to be doing its job. I had a vibration and it was the lower engine mount and once replaced the vibration ceased.
    tjwhite721 likes this.
    hbrigiii is offline Cadillac Owners Member
    Automobile(s): Cadillac 2006 DTS
    Dec 2006
    Rockport, Texas
    44
    Sure looks like it's time to replace it. Mine on my 2006 DTS failed just like yours at about 100,000 mi. I had it replace while I waited at the shop. Didnt seem to long to do. I think
    they charged me about one hour. If this upper one has failed, be sure to check the lowers. This one being broken will have put undue strain on the lowers which are just as old.
    Good luck.
    thomas.jain1 is offline Cadillac Owners Member
    Jul 2014
    36
    Bad motor mount or something else?
    i have an 1981 cutlass periodically i experience a derate from the trans it seems out of nowhere i can feel the engine jump a little then it become hard to accelerate then eventually it'll go back to normal i doubt its the trans because its been taking place for quite some time it feels like its slipping but it only happens every so often(jump in and out of gear as it feels that way)what can cause this? and what type of affects do u see from a bad mount besides the added vibrations?
    LED billboard truck
    Abecadillac2009's Avatar
    Abecadillac2009 is offline Cadillac Owners Member
    Automobile(s): DTS
    Jun 2014
    11
    Does the vibration happen when you are idling while waiting for the light to change.
    I have a similar situation but I am not sure what is causing it.
    Sep 2013
    SW Washington
    43
    I actually feel no vibration at all. Just noticed the cracking on top and knew it was going to lead to other problems if not taken care of.
    Sep 2013
    SW Washington
    43
    Got the part. I checked around 3 places and all of them were in the $65 to $70 range on these. Prices must have gone up. Anyways I went to tackle this and found it to be very easy. I don't know why somebody said you have to take the wheel off and the splash gaurd. It can easily be done all on the top. There were 2 bolts actually holding the mount in place. Then I removoed 2 10mm bolts holding the coolant expansion tank down. When these 2 nuts were removed it gave me plenty of clearance to remove the torque strut out of there and install the new one. There was one other cross brace holding the actual torque strut down and that is a brace located just above expansion tank. Took me about 20 minutes to remove the 3 nuts and 2 bolts and replace the new one.
    Sep 2013
    SW Washington
    43
    1st top bolt of torque strut
    Rear torque strut bolt with brace.
    Brace bolt that attaches on top of torque strut rear
    10mm bolt on overflow tank
    2nd 10mm bolt on overflow tank. Remove these 2 bolts and you can easily pull out the torque strut and have clearance.
    ltdltc's Avatar
    Jun 2003
    MA
    35
    490
    Quote Originally Posted by beauimpala View Post
    That was me I was thinking of the serpentine belt replacement. With that you need to remove the wheel and inner splash shield.
    Edited my post so no one gets bad info.
    beauimpala likes this.
    tjwhite721's Avatar
    tjwhite721 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac DTS, 1999 Cadillac Seville
    Jul 2008
    Bloomsburg,PA
    315
    Quote Originally Posted by ltdltc View Post
    Do you mean the rear engine mount, trans mount, or front mount that you changed as well?
    Glen773 is offline Cadillac Owners Member
    Automobile(s): 2007 DTS
    Oct 2014
    KY
    61
    36
    What is the right name for the torque strut in the first post? I need one and have found 3 different names for it. I have found a "front, left, and rear. I found one at RockAuto.com that looks like it and they call it the right one. I need the one on the right side of the car on top of the engine.
  14. Remove Advertisements
