2006 DTS Clunking Noise
Results 1 to 4 of 4
Cadillac DTS Forum - 2006 through 2012 Discussion, 2006 DTS Clunking Noise in Past Cadillac Vehicle Discussion; I hear a clunking noise whenever I step on gas, brake, turn left or turn right. I have had the ...
    S Amidei is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Jun 2014
    1
    I hear a clunking noise whenever I step on gas, brake, turn left or turn right. I have had the lower control arms on the front replaced, the front lower engine mount replaced, the left front hub bearing, the rear engine mount, the left side engine mount, the left rear lower control arm, the right rear lower control arm, the front struts and bearing plates and the right front hub bearing replaced to the tune of around $5500. I am still hearing the same noise. Anyone else having this problem? Anything I haven't replaced? Thanks.
    brucehammond is offline Cadillac Owners Member
    Automobile(s): 2006 DTS, 2013 ATS 2.5
    Nov 2012
    57
    60
    I had a clunk up front when turning and my tie rod was bad. Clunk went away after replacement.
    DSNCB919 is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac Seville 2003 Cadillac DTS 2010 DTS Platinum
    Jun 2009
    North Carolina
    28
    538
    I get that same clunk only when I hit gas almost like a click doesn't do it all the time but when it does feels like car slightly jolts
    Maunus is offline Cadillac Owners Member
    Automobile(s): DTS
    Dec 2008
    48
    Re: 2006 DTS Clunking Noise
    i am NO mechanic. but, i had a distinct clunk. one sway bar link was totally broken off. replaced them both. that did it! good luck
    bob
  7. Remove Advertisements
