DTS tire size change ?
Results 1 to 6 of 6
Cadillac DTS Forum - 2006 through 2012 Discussion, DTS tire size change ? in Past Cadillac Vehicle Discussion; Going from a 18x 7.5 to a 18x 8.5 I know the tires won't fit but will there be clearance ...
    BlueAngel#07's Avatar
    BlueAngel#07 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 DTS PERFORMANCE
    Feb 2013
    Minnesota
    1,109
    Going from a 18x 7.5 to a 18x 8.5 I know the tires won't fit but will there be clearance issues on the inner wells?
    I know they are going to stick out about 1/2 inch to 3/4's farther than OEM but I think I will be ok with that.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,575
    Re: DTS tire size change ?
    No need to hijack a "quiet tire" thread for a "tire size" question. Apples and oranges.
    Feb 2013
    Minnesota
    1,109
    Pardon....
    Feb 2006
    56,575
    No problem - your own particular question is now open for discussion.
    Rimwidth, within reason, will not cause rubbing in fenderwells - it's tire section width and treadwidth.
    Look up your original stock tire size in www.tirerack.com and compare that with your new tires. An inch or so of treadwidth should not cause problems. Outside tire diameter is critical because, if you go more than 0.3 inch one way or the other you begin to affect speedo and transmission calibrations.
    Smaller diameters roll more revolutions per mile (fast speedo) while larger diameters roll less revs per mile - slow speedo.
    Enigmatic is offline Cadillac Owners Member
    Automobile(s): 2006 DTS Performance
    Sep 2013
    Va.
    45
    1
    Feb 2013
    Minnesota
    1,109
    Quote Originally Posted by Enigmatic
    Thanx, that's really handy.
  9. Remove Advertisements
