06 dts intermitant overheating
Results 1 to 6 of 6
Cadillac DTS Forum - 2006 through 2012 Discussion, 06 dts intermitant overheating in Past Cadillac Vehicle Discussion; I have an 06 DTS that has just recently begun overheating. It happens about 5 minutes after first take off ...
    cef123 is offline Cadillac Owners Member
    May 2014
    I have an 06 DTS that has just recently begun overheating. It happens about 5 minutes after first take off for a trip. Temp goes all the way to red an says pull over and stop. Before even getting stopped it starts dropping and doesn't happen again until trip is done and car cools down. But it happens every time I drive it after it is cooled down.
    RobsDeville is offline Cadillac Owners Fanatic
    Automobile(s): 1994 Concours, 2007 DTS Performance, 2008 DTS Platinum Perf.
    Jan 2008
    Ellicott City, MD
    30
    186
    Re: 06 dts intermitant overheating
    Check coolant level. Does the heater work?
    Add coolant. There is most certainly a leak somewhere. Probably at the waterpump or in a hose.
    This is a serious issue. The Northstar does the best job of dealing with heat than any other aluminum engine out there. But it is still aluminum. Do not fill or check coolant while hot!
    Actually, after reading again, since it is not always a problem. Sounds like a bad thermostat that isn't opening itself up properly!
    May 2014
    Coolant level remains fine. No signs of leaks. I thought thermostat also. Just wanted to check with someone more familiar. Once it happens and temp goes down it doesn't
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    I would guess thermostat...
    cadillacpaul1979's Avatar
    cadillacpaul1979 is offline Cadillac Owners Member
    Feb 2014
    52
    I had a 2000 deville that started like like ended up needling head gaskets
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I say thermostat as well.
  9. Remove Advertisements
