2006 DTS not started in 2 years. How to proceed?
Results 1 to 12 of 12
Cadillac DTS Forum - 2006 through 2012 Discussion, 2006 DTS not started in 2 years. How to proceed? in Past Cadillac Vehicle Discussion; Hello I have a 2006 DTS Luxury III with the Performance Package. The car has not been started for 2 ...
    iMissTheDTS is offline Cadillac Owners Member
    Automobile(s): None
    Feb 2014
    None
    15
    Hello I have a 2006 DTS Luxury III with the Performance Package. The car has not been started for 2 years and has been outside through 2 Chicago winters. My question is, what preventative maintenance steps do I take prior to attempting to start it? The car has no known issues prior to parking it, well other than the notorious flickering headlight.
    grullon10's Avatar
    grullon10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 cadillac dts
    Dec 2012
    46
    553
    New battery get oil change if you can get royal purple synthetic oil 5 w 30 and get fresh gas in it.
    Automobile(s): None
    Feb 2014
    None
    15
    Re: 2006 DTS not started in 2 years. How to proceed?
    Thanks grullon10. I see the the royal purple on Summit Racing I can get that. So I assume I should have it towed to a mechanics garage and have the oil and gas replaced.
    just heard someone say I need to have the rotors turned before driving... any comments? An ounce of prevention... as they say
    Jammer53 is offline Cadillac Owners Member
    Automobile(s): 2008 DTS
    May 2011
    75
    22
    drain any existing gas make sure antifreeze is topped off fully charged battery, new plugs that should give you fuel and spark, provided the rest of the ignition system is functional. Get it started, then make sure brakes and tires are safe before attempting to do anything beyond a yard drive. and have a qualified mechanic you trust look at it
    BlueAngel#07's Avatar
    BlueAngel#07 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 DTS PERFORMANCE
    Feb 2013
    Minnesota
    1,054
    Quote Originally Posted by Jammer53
    I second checking the tires, looking closely for tire rot, sidewall cracking as well as in the tread.
    Automobile(s): None
    Feb 2014
    None
    15
    Thanks Jammer53, in regards to the antifreeze should I use the 50/50 or 100%?
    Thanks for the input BlueAngel#07, I am not very mechanically inclined? Is the wear and tear something I would be able to obviously see or should I remove the tires and take them by a shop?
    May 2011
    75
    22
    If the tires have dry rot, you will see obvious cracks in the sidewalls. Look closely around the rim where the tire seals. With regard to the antifreeze, doesn't really matter if 50/50 or not, just so long as you make sure it's full so it doesn't overheat.
    Bottom line is anything we tell you here is ONLY to get you to a SAE certified repair shop where you have made arrangements to have the car gone over.
    Good luck. I loved my 06 DTS so much, I bought an 08 ;o)
    Kent7100's Avatar
    Kent7100 is offline Cadillac Owners Fanatic
    Nov 2012
    100
    Don't forget to flush the brake fluid too!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,850
    The GM recommended coolant ratio is 50/50 with 70/30 permitted for extreme cold climates.
    As posted, basically ALL fluids in the car/engine are suspect and should be replaced with new.
    Because the car has been sitting for so long I'll take exception to using a boutique synthetic oil as a first startup change. Any name brand 5W-30 oil will do, exactly 7.5 quarts with filter .......... prefill the filter, get the car running, check it out, drive it 250 miles or so, THEN go to the oil/filter of your choice. ($75 worth of Royal Purple is a lot to dump after no mileage) You don't know just what sort of rust and condensation is in that engine, stored outdoors, so the plain ol' dino oil is merely a "flush" agent, so to speak.
    If you know the car intimately, disconnect the ignition coil cassette ICM connectors and roll the engine over with the starter until oil pressure rises - and you'll probably need to connect a mechanical pressure gauge to the oil filter adapter at the pressure sending switch port. Royal, screaming, murderous pain in the butt.
    In any event, bringing a severely neglected car back to life is a labor of love.
    ogbuehi is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Deville, 2011 DTS
    Jul 2004
    washington d.c.
    852
    Just my humble opinion having done this several times. Check the fluid levels and tires and start it up. I even left my Deville outside for 14 months in salty air of Hawaii. That sucker turned over like it was brand new. I just recently had to do the same thing again for both of my cars. Both of them started up like brand new. Yes, even my 19 year old deville.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by grullon10
    Change the oil. Brand is totally irrelevant.
    grullon10's Avatar
    Dec 2012
    46
    553
    I recommend royal purple because is a very oil to break in a motor
  15. Remove Advertisements
