Just got a DTS, noob memory seat question! - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Like Tree2Likes
Cadillac DTS Forum - 2006 through 2012 Discussion, Just got a DTS, noob memory seat question! in Past Cadillac Vehicle Discussion; Originally Posted by showcoach97 How do I perform a reset? I removed the negative battery cable for about 10 minutes ...
  1. #16
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Just got a DTS, noob memory seat question!
    Quote Originally Posted by showcoach97 View Post
    How do I perform a reset? I removed the negative battery cable for about 10 minutes but the memory seats settings were saved. Is there another way to reset the system?
    There is a way to REBOOT all of the electronic modules in the entire car.
    Sometimes (lots of times) that will fix random electrical gremlins.
    Remove BOTH battery cables... negative cable FIRST...
    Touch both cables together for 5 seconds or so, making sure they have good contact with each other.
    This will drain all the capacitors in the system.
    While you have the cables off... undo the one bolted to the floor.
    Take a little piece of sandpaper and sand the paint away from the attachment point.
    It will then have a better ground.
    Re-attach the battery cables... negative cable LAST...
    You will have to do the window EXPRESS UP learn again and you MAY have to do the memory seat settings again.
    Sometimes they will forget the seat settings and sometimes they don't.
  2. #17
    showcoach97 is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    May 2014
    Wichita
    33
    Thanks Super Jim! I'll post my after action results.
  3. #18
    May 2014
    Wichita
    33
    I have to report that the reboot didn't solve my problem. I even touched the negative and positive battery cables together 3 to 4 times at 5 to 10 seconds each time. I did everthing suggested except for removing the ground bolted to the floor. It is on tight and I didn't want to strip the head of the bolt. Once I reconnected the negative and positive cables back to battery, I had to reset my clock and reprogram the windows. However, the memory seat settings were saved. I could make another attempt to unbolt the ground cable and clean it with sand paper.
    Would you have any other suggestions?
  5. #19
    Eddie39's Avatar
    Eddie39 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS LUX II 65k - Once owned 1998 Deville & 2002 Deville
    Jun 2011
    South Carolina Lowcountry
    178
    [QUOTE="showcoach97"]I have to report that the reboot didn't solve my problem. I even touched the negative and positive battery cables together 3 to 4 times at 5 to 10 seconds each time. I did everthing suggested except for removing the ground bolted to the floor. It is on tight and I didn't want to strip the head of the bolt. Once I reconnected the negative and positive cables back to battery, I had to reset my clock and reprogram the windows. However, the memory seat settings were saved. I could make another attempt to unbolt the ground cable and clean it with sand paper. Would you have any other suggestions?[/QUOTE
    It's possibly that your key FOB was relearn as a no. 3 or higher. Try relearning them to see if that's your problem.
  6. #20
    May 2014
    Wichita
    33
    Eddie39,
    I don't think the fobs have anything to do with the memory seats not working. My #1 fob causes the seat settings to be recalled when I unlock the driver's door when the recall feature is active using the dic.
  7. Remove Advertisements
