When a bearing has play
Results 1 to 5 of 5
Cadillac DTS Forum - 2006 through 2012 Discussion, When a bearing has play in Past Cadillac Vehicle Discussion; The driver side bearing on 06 dts has play when you moved it 3 to 9 that will couse a ...
    grullon10's Avatar
    grullon10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 cadillac dts
    Dec 2012
    46
    553
    The driver side bearing on 06 dts has play when you moved it 3 to 9 that will couse a knowking noise when the steering wheel is turn right.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: When a bearing has play
    Quote Originally Posted by grullon10 View Post
    If you are sure the bearing has play in it... replace the hub.
    The bearings are included with the hub.
    I would also recommend replacing the pads while you have it apart...
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    .......... and make sure the play is not the tie rod end - if worn/loose they will rattle when the tire is rocked at 3 and 9. Bearings usually rattle at 12 and 6.
    grullon10's Avatar
    Dec 2012
    46
    553
    I just found out that the knowing noise is from the left control arm that both the front and rear bushings ate bad and is moving back and forth every time I brake.
    jazoo is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS
    Jun 2012
    366
    The only way I know to check the bearing play is by jacking up the Caddy and turning the wheel by hand. I mean you should not feel any roughness or play while turning the wheel by hand. On the other hand there could other contributing causes such as loose (or play in) tie rod ends.
  8. Remove Advertisements
