rear valve cover gasket is leaking
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By polo14
Cadillac DTS Forum - 2006 through 2012 Discussion, rear valve cover gasket is leaking in Past Cadillac Vehicle Discussion; So you have to remove the engine to replace rear valve cover gasket ???...
    polo14 is offline Cadillac Owners Member
    Automobile(s): 2006 DTS 2004 SLS
    Apr 2011
    3
    jsorrell's Avatar
    jsorrell is offline Cadillac Owners Fanatic
    Automobile(s): Black 2009 Cadillac DTS Luxury
    Oct 2006
    New England
    33
    275
    Re: rear valve cover gasket is leaking
    Hi there! If this is for your 2004 SLS you are in the wrong forum. Check out the Cadillac Seville Forum. You'll get better answers there. If not I hope someone can help you out here :-)
    Apr 2011
    3
    No I have a 2006 DTS now ...
    jsorrell likes this.
    danog is online now Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    455
    takes about 1 hour in car
    big miracle's Avatar
    big miracle is offline Cadillac Owners Member
    Jul 2011
    Hampstead, North Carolina, Uni
    47
    5
    I have the same problem, rear valve cover leaks. I was told it's Easier to take the motor out to repair. True or not?
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    684
    Quote Originally Posted by big miracle View Post
    Crazy Not True.
    Greg81 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2008
    32
    I think the 2005 and earlier Deville/DTS required the lowering of the engine cradle (or a similar procedure) to remove the rear valve cover. The 2006 & up DTS does not require this. As per the service manual the cover can be removed fairly easily and without lowering the cradle or shifing the position of the engine in any way. I have a 2006 DTS with a leaking rear valve cover and I plan to do the job soon.
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    567
    Correct, but even on the 05 down it's easy to do without removing the engine.
    ponyboyt is offline Cadillac Owners Enthusiast
    Automobile(s): 97, 97, RIP 98, 99 STS with Jakes studs
    Apr 2009
    Ontario, Canada
    41
    718
    I just did this yesterday. Loosen the rear bolts and drop the front of the cradle. Use a jack to lower the front. This rocks the engine forward, tilts the rear cover away from the firewall, makes more room. You can get at the AIR easier and remove it too. I also removed a bracket from the passenger side firewall that I think had wires clipped to for remote start.
    DevilleDeeman's Avatar
    DevilleDeeman is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS4 Premium, Saturn Vue XR
    Sep 2008
    Ontario, Canada
    48
    483
    Try Flex-seal....LMAO! It supposedly seals all leaks.
    http://www.asseenontv.com/flex-seal/detail.php?p=346830
  13. Remove Advertisements
