Results 1 to 9 of 9
Thread: Need Help, 6 DTS won't start
    Ozlander is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS
    Mar 2011
    Rose Hill, Kansas
    78
    131
    5*, wife starts car, drives to Doc, drives to bank, comes out car is dead. Nothing works until you turn the key on. Dash lights on, radio works, heater works, nothing else. Paging thru looking for battery volts, all info is dashes, like VOLTS --.-. Nothing happens when you try to start, lights don't dim, nothing changes.
    It's got to be a fuse or link, but where.
    Any ideas?
    Thanks,
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Need Help, 6 DTS won't start
    Quote Originally Posted by Ozlander View Post
    Any ideas?
    Thanks,
    Put the shifter in "N" and try to start it or move the shifter back and forth from PARK to 1st a few times...
    It may not be in park real good.
    Mar 2011
    Rose Hill, Kansas
    78
    131
    I did try that, but it's not that, the indicator the shows what gear you're in doesn't appear. ECMs not getting any power, no interior lights, nothing on door control panel works.
    Car is completely dead until you turn a ignition switch on. Battery has 12.22 volts, at battery, rear seat fuse box and front fuse box.
    Darn cold out to check for very long. luckily it's only 4 miles away.
  5. #4
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    There is a way to REBOOT all of the electronic modules in the entire car.
    Sometimes ( lots of times) that will fix random electrical gremlins.
    Remove BOTH battery cables... negative cable FIRST...
    Touch both cables together for 5 seconds or so, making sure they have good contact with each other.
    This will drain all the capacitors in the system.
    While you have the cables off... undo the one bolted to the floor.
    Take a little piece of sandpaper and sand the paint away from the attachment point.
    It will then have a better ground.
    Re-attach the battery cables... negative cable LAST...
    You will have to do the window EXPRESS UP learn again and you MAY have to do the memory seat settings again.
    Sometimes they will forget the seat settings and sometimes they don't.
  6. #5
    jazoo is offline Cadillac Owners Fanatic
    Jun 2012
    366
    I did try that, but it's not that, the indicator ...............................box and front fuse box.
    I think there is something wrong in the electric circuit and it's very difficult for you to do the quick diagnostics especially in this bone chilling weather. Unless you have a heated garage I would recommend to get it towed to your local auto shop & let'm figure out & correct the problem.
  7. #6
    Mar 2011
    Rose Hill, Kansas
    78
    131
    Got a heated garage, may have to get it towed. High of 38* tomorrow will help.
    Quote Originally Posted by Superjim View Post
    I'll give that a try. Surprisingly, the memory seat is the only thing I have found that works with the key off.
  8. #7
    Mar 2011
    Rose Hill, Kansas
    78
    131
    Got the car back Wed, luckily the local garage is across the street from the bank parking lot.
    They worked on it a couple of times in the parking lot and gave up and pushed it across the street into the garage when it was my turn.
    So, $305 for a new BCM, $70 labor, $80 for a programmer guy to program it, taxes, etc. $488 total.
    I'm sure the stealership would have doubled that or more.
    Me happy.
  9. #8
    Jun 2012
    366
    I assume the BCM is the Body Control Module. So, where is the BCM located in the DTS?
  10. #9
    danog is offline Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    443
    Behind the glove box to the right
  • You may not post replies
