Aux problem
Results 1 to 10 of 10
Cadillac DTS Forum - 2006 through 2012 Discussion, Aux problem in Past Cadillac Vehicle Discussion; Ok so my recently purchased DTS has been having quite a few issues. This time I noticed I think the ...
    lpp71 is offline Cadillac Owners Member
    Automobile(s): 2006 DTS Performance
    Jun 2010
    21
    Aux problem
    Ok so my recently purchased DTS has been having quite a few issues. This time I noticed I think the aux connector is lose. I only get like one side of the speakers to work unless I play with the connector, or I get a lot of static. If I push the connector up and slightly to the right it has no issues for awhile. I tried many cables. Is this a known issues? Just a solder fix??
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Aux problem
    The few times I have used mine... it worked just fine... no issues.
    I normally listen to XM or homemade CD's...
    BIGDADDYCADDY07 is offline Cadillac Owners Fanatic
    Automobile(s): 07 dts 1986 fleetwood brougham d'elegance
    Jun 2011
    BROCKTON MA
    136
    Re: Aux problem
    mine works fine use it all the time sounds like somebody b4 you had a heavy hand loose connection at circuit board
    Jun 2010
    21
    Re: Aux problem
    Would this be something that would be accessible with the radio removed? If so would soldering be the issue?
    wastingjake's Avatar
    wastingjake is offline Cadillac Owners Member
    Automobile(s): DTS Luxury III
    Mar 2013
    East Coast
    61
    My sisters suburban has the same problem. Someone somehow was just rough on the connection in someway and kinda broke it loose. Depending on the cost I would just try to find someone selling a oem radio and replace it
    Jun 2010
    21
    Re: Aux problem
    I would replace the radio but it's the navigation system and therefore very expensive. I have about $150 I'm willing to spend on getting this fixed. Pulling the radio itself doesn't appear hard.
    jazoo is offline Cadillac Owners Fanatic
    Jun 2012
    363
    Re: Aux problem
    Welcome to the DTS Forum and congrats on getting a 2006 Performance Caddy!!
    I'm surprised that you're willing to spend only $150 on getting the unit w/navigation system fixed. So, how many miles are on the odometer & how much you paid for it? I don't know what other issues you have/had with this luxury but you should be willing to cough up a little more than $150.
    You can go a local audio/visual shop & they should be able to figure out the connector(s) and/or soldering issues.
    Jun 2010
    21
    Re: Aux problem
    It has 81k and I paid $10,000. A used replacement nav radio is only $300 from LKQ so I wouldn't thinking paying more then half the cost of the radio for a simple remove and solder is in order. I suppose if no one wants to fix it I'll replace it.
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Aux problem
    Quote Originally Posted by lpp71 View Post
    The replacement radio will have to be programmed to your car by the dealer...
    Jun 2010
    21
    Re: Aux problem
    Quote Originally Posted by Superjim View Post
    Of course, but that's only $60. I still think $150 for an hour job is fair.
  13. Remove Advertisements
