Another heated seat failure (Question)
Results 1 to 7 of 7
Cadillac DTS Forum - 2006 through 2012 Discussion, Another heated seat failure (Question) in Past Cadillac Vehicle Discussion; Ok so I have a 2006 DTS with 81,000 miles. The front heated seats failed on my recently with a ...
    lpp71 is offline Cadillac Owners Member
    Automobile(s): 2006 DTS Performance
    Jun 2010
    21
    Ok so I have a 2006 DTS with 81,000 miles. The front heated seats failed on my recently with a odor of burning plastic.
    I took it to the dealer who said the module and connector melted and needed replacing (about $600 for everything)
    So my questions are:
    1) They are claiming they ordered an 'improved and revised' module, is this the case? Will it prevent more issues?
    2) Are there time limits on how long you should have the heated seats on for, could this have caused the issue?
    3) is $600 fair for everything?
    danog is online now Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    442
    Re: Another heated seat failure (Question)
    Its the plug connector that melt. The pin heats up from the load.
    Do it your self
    http://www.cadillacforums.com/forums...ml#post3288711
    Jun 2010
    21
    They said the module connector was melted also, is that possible? Also does the "improved" module fix the unit from sending a current that would melt it in the first place?
    Atavar is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS
    Aug 2013
    ND
    61
    211
    All this should take is replacing the plug and connector with some that are actually rated for the current used.
    Jun 2010
    21
    The dealer didn't think the connector they are replacing it with was improved. I called another dealership and they charge more money. I might just have them do it so they can warranty it if it breaks. I just want it to last 3-4 years once replaced. Should I limit the use of the heated seat once fixed?
    beauimpala is offline Cadillac Owners Member
    Automobile(s): 2006 DTS 1990 Brougham
    Sep 2013
    SW Washington
    43
    I don't have time to dink around with the repair. Stealership wanted $600 to repair. Took it to a electrical auto repair shop. $160 to put on the new connector and re-pin.
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    556
    Seems like it is usually the female pin on the connector itself. Since I fixed mine, I try to limit the amount of time that both seats are running. If mine fails again, I may look into parallel loading 2 pins as a more final fix to the problem.
  10. Remove Advertisements
