Popping sound when starting up
Results 1 to 9 of 9
Cadillac DTS Forum - 2006 through 2012 Discussion, Popping sound when starting up in Past Cadillac Vehicle Discussion; I am thinking this may be a low voltage sign, i.e. that the battery is failing. When the car is ...
    dgwildt is offline Cadillac Owners Member
    Automobile(s): 2007 DTS
    Dec 2013
    1
    I am thinking this may be a low voltage sign, i.e. that the battery is failing. When the car is started - sometimes - it pops. Kinda loud. Sounds like its coming from the front. Any ideas? thanks.
    Eddie39's Avatar
    Eddie39 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS LUX II 65k - Once owned 1998 Deville & 2002 Deville
    Jun 2011
    South Carolina Lowcountry
    78
    179
    Re: Popping sound when starting up
    I bought my 07 DTS February 2012 and I had a loud bang sound to occur when starting the car several times. I want to think it's coming from the sound system. To me it sounds like someone shot a gun. I change my battery a couple of months ago because of the age and it has not had happen since but time will tell. I also clean where the ground cable connects to the body like Jim recommends in case there was an arc. I was surprise to find paint all down in the threads making a good ground impossible.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    Quote Originally Posted by dgwildt View Post
    Hello dgwildt,
    Welcome to Cadillac Owners. I apologize you are experiencing a concern with your vehicle. If you would like to have your vehicle diagnosed by your dealership, please let me know so I can assist throughout that process. Please send me a private message or email to socialmedia@gm.com that includes your full contact information, VIN and current mileage. Gregory and I monitor the Cadillac forums and are here to assist, so don't hesitate to contact us if you have any questions.
    Sincerely,
    Laura M.
    Cadillac Customer Care
    jsorrell's Avatar
    jsorrell is offline Cadillac Owners Fanatic
    Automobile(s): Black 2009 Cadillac DTS Luxury
    Oct 2006
    New England
    33
    275
    Mine does that every now and then also. I'm pretty sure it comes from the sound system. Not sure whats causing it. My car has a new battery so I doubt its that. Maybe bad grounding somewhere in the audio system?
    Eddie39's Avatar
    Jun 2011
    78
    179
    Quote Originally Posted by jsorrell View Post
    Did you clean the ground connection where the negative cable connects to the body?
    jsorrell's Avatar
    Oct 2006
    New England
    33
    275
    Not a clue the dealership put a new one in when I bought it. :-)
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    There is a way to REBOOT all of the electronic modules in the entire car.
    Sometimes ( lots of times) that will fix random electrical gremlins.
    Remove BOTH battery cables... negative cable FIRST...
    Touch both cables together for 5 seconds or so, making sure they have good contact with each other.
    This will drain all the capacitors in the system.
    While you have the cables off... undo the one bolted to the floor.
    Take a little piece of sandpaper and sand the paint away from the attachment point.
    It will then have a better ground.
    Re-attach the battery cables... negative cable LAST...
    You will have to do the window EXPRESS UP learn again and you MAY have to do the memory seat settings again.
    Sometimes they will forget the seat settings and sometimes they don't.
    Eddie39's Avatar
    Jun 2011
    78
    179
    Quote Originally Posted by Superjim View Post
    I did this when I replaced my battery. Haven't heard the loud pop but time will tell. Thanks Jim for your input.
    jsorrell's Avatar
    Oct 2006
    New England
    33
    275
    I'll have to give it a shot sometime when its above 0 out lol. Right now Its -10*F which means its warming up. When I was driving into work the DTS said -14... Gotta love New England winters lol
  12. Remove Advertisements
