interior temp sensor making noise. How to fix?
Results 1 to 10 of 10
Cadillac DTS Forum - 2006 through 2012 Discussion, interior temp sensor making noise. How to fix? in Past Cadillac Vehicle Discussion; Hi. I I just bought a 2006 DTS this weekend. There is a clicking noise coming from the little tiny ...
    91 zeee is offline Cadillac Owners Member
    Automobile(s): 2002 deville
    May 2011
    47
    17
    Hi. I I just bought a 2006 DTS this weekend. There is a clicking noise coming from the little tiny grille on the dash to the left of the steering wheel. I read on the STS forum that this is a interior temp sensor and there is a fan in there that can start to go bad and make noise. Is it the same on our DTS? If so, does anyone have a copy of the service manual procedure for replacing it? The noise is driving me crazy! Thanks!
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: interior temp sensor making noise. How to fix?
    Quote Originally Posted by 91 zeee View Post
    It is called the ASPIRATOR fan... just in case you may need to order one.
    Sometimes it is just dust and lint buildup on the fan.
    It may just need cleaning...
    May 2011
    47
    17
    ok. thanks. one more question...how to i get to it and get it out on a dts? I read something about popping it out with a paper clip but then I also read that the fan is not right at the grille??
  5. #4
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    I am not sure... I have never had to take mine out... YET...
  6. #5
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,566
    If it's anything like the earlier Deville and Seville aspirator modules, you yank off the dash end - the one with the window heat duct - and work in there. A hex head screw (magnetic tools and mechanics fingers). Fish out the wiring connector and then the small aspirator module.
    Either remove the sticker on the muffin fan hub and use 2 drops of multigrade synthetic on the bearing end, replace sticker or new seal, assemble. OR, a new module is about $40. Talk to Chris in parts at Rippy Cadillac over there >>>>
    Be careful with that grille when you blow out the tunnel with computer "canned air". Just inside the tunnel is a tiny thermistor bead - the "sensor" that feeds the module. The muffin fan simply moves air.
  7. #6
    Cadillacman916 is offline Cadillac Owners Member
    Automobile(s): 07dts perf. 04 dts,06 dts limo,11 dts, 13 escalade, 13 xts
    Jan 2013
    Sacramento, ca
    31
    14
    Try shooting some compressed air in there.. I do it to all mine about once a month anyway to get the dust outta all the cracks inside the car. Works great
  8. #7
    May 2011
    47
    17
    I ordered a new one today. Once I get it installed I'll try to keep it cleaned up. thanks!
  9. #8
    Feb 2006
    55,566
    Keeping the dust at bay is one thing - dried lubricant in the muffin fan sleeve bearing is another. Same as a noisy PC or laptop cooling fan. Oil it.
    Some models are prone to screech like a shot cat in cold temperatures, yet be quiet all summer.
  10. #9
    May 2011
    47
    17
    good to know. Thanks!
    Quote Originally Posted by Submariner409 View Post
  11. #10
    jazoo is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS
    Jun 2012
    363
    Quote Originally Posted by Cadillacman916 View Post
    Does it get that windy & dusty so frequently in your nook of the woods that you have to use compressed air once a month?
  12. Remove Advertisements
