P0300 and C0561 Codes 2008 DTS, LUX III, 114,000 miles
Results 1 to 7 of 7
Cadillac DTS Forum - 2006 through 2012 Discussion, P0300 and C0561 Codes 2008 DTS, LUX III, 114,000 miles in Past Cadillac Vehicle Discussion; Good morning all, Week+ of snow, ice, slush in central Minnesota. Temps in minus degrees Car is driven 5 miles, ...
    NATOAWACr is offline Cadillac Owners Member
    Automobile(s): 2008 DTS
    May 2013
    Central, MN
    7
    Good morning all,
    Car is driven 5 miles, parked outside for 8 hours then 5 miles back and garaged overnight in temp range 20-30 degrees.
    Recieved Service Stabilitrak and Parking Asssit Off DIC messages.
    OnStar reported codes P0300 and C0561.
    Hoping ice/slush/snow build-up may have had an effect I garaged the car at 50+ degrees for two days.
    Are there any plugs/connectors I can check or should I just eat it and take it to Cadillac for more diagnostics. Any idea on what I would pay to have problem(s) identified? Thanks for any advice.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: P0300 and C0561 Codes 2008 DTS, LUX III, 114,000 miles
    The P0300 indicates a MISFIRE on one or more cylinders...
    That is most likely what is causing the C0561.
    Fix the P0300 and the C0561 will will probably go away also.
    May 2013
    Central, MN
    7
    Thanks for the superfast reply SUperJim! Checked codes at autozone and it reads a misfire on cylinder 1. I had the plugs changed 4,000 miles ago at 110,000. Any direction I should move to try and resolve the #1 misfire?
    Thanks again,
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Start with checking that the wire/connection on top of the plug is all OK.
    Something may be loose and not making a good connection.
    I may be wrong, but I THINK #1 is 1st plug on the passengers side on the REAR bank... next to the fire wall..
    Atavar is offline Cadillac Owners Fanatic
    Aug 2013
    ND
    61
    211
    Is #1 the hard to get to plug that lazy mechanics tend to skip because it takes so much time?
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by Atavar View Post
    No... that's number 2 and number 3... the two center ones.
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    684
    This is why I ask for the parts back.
  10. Remove Advertisements
